26
It seems to be a wide impression that quantum mechanics is not deterministic, e.g. the world is quantum-mechanical and not deterministic.
I have a basic question about quantum mechanics itself. A quantum-mechanical object is completely characterized by the state vector. The time-evolution of state vector is perfectly deterministic. The system, equipment, environment, and observer are part of the state vector of universe. The measurements with different results are part of state vector at different spacetime. The measurement is a complicated process between system and equipment. The equipment has $10^{23}$ degrees of freedom, the states of equipment we neither know nor able to compute. In this sense, the situation of QM is quite similar with statistical physics. Why can't the situation just like statistical physics, we introduce an assumption to simply calculation, that every accessible microscopic state has equal probability? In QM, we also introduce an assumption about the probabilistic measurement to produce the measurement outcome.
PS1: If we regarded non-deterministic is intrinsic feature of quantum mechanics, then the measurement has to disobey the Schrödinger picture.
PS2: The bold phase argument above does not obey the Bell's inequality. In the local hidden variable theory from Sakurai's modern quantum mechanics, a particle with $z+$, $x-$ spin measurement result corresponds to $(\hat{z}+,\hat{x}-)$ "state". If I just say the time-evolution of universe is $$\hat{U}(t,t_0) \lvert \mathrm{universe} (t_0) \rangle = \lvert \mathrm{universe} (t) \rangle.$$ When the $z+$ was obtained, the state of universe is $\lvert\mathrm{rest} \rangle \lvert z+ \rangle $. Later the $x-$ was obtained, the state of universe is $\lvert\mathrm{rest}' \rangle \lvert x- \rangle $. It is deterministic, and does not require hidden-variable setup as in Sakurai's book.
PS3: My question is just about quantum mechanics itself. It is entirely possible that the final theory of nature will require drastic modification of QM. Nevertheless it is outside the current question.
PS4: One might say the state vector is probabilistic. However, the result of measurement happens in equipment, which is a part of total state vector. Given a probabilistic interpretation in a deterministic theory is logical inconsistent.
Řídící
  • 6,847
user26143
  • 6,571
7 Answers7
I agree with much of what you write in your question. Whether quantum mechanics is considered to be deterministic is a matter of interpretation, summarised in this wiki comparison of interpretations. The wiki definition of determinism is this context, which I think is entirely satisfactory, is
Determinism is a property characterizing state changes due to the passage of time, namely that the state at a future instant is a function of the state in the present (see time evolution). It may not always be clear whether a particular interpretation is deterministic or not, as there may not be a clear choice of a time parameter. Moreover, a given theory may have two interpretations, one of which is deterministic and the other not.
In, for example, many-worlds interpretation, time evolution is unitary and is governed entirely by Schrödinger’s equation. There is nothing like the "collapse of the wave-function" or a Born rule for probabilities.
In other interpretations, for example, Copenhagen, there is a Born rule, which introduces a non-deterministic collapse along with the deterministic evolution of the wave-function by Schrödinger’s equation.
In your linked text, the author writes that quantum mechanics is non-deterministic. I assume the author rejects the many-worlds and other deterministic interpretations of quantum mechanics. Aspects of such interpretations remain somewhat unsatisfactory; for example, it is difficult to calculate probabilities correctly without the Born rule.
innisfree
  • 15,425
The difference between statistical physics and quantum mechanics is that, in statistical physics, it is always reasonable to either measure a quantity, or demonstrate that the effect of that quantity can be bundled into an easy to work with random variable, often through the use of the Central Limit Theorem. In such situations, it can be shown that the answer will be a deterministic answer plus a small perturbation from the random variables with a 0 expectation and a very small variance.
In quantum mechanics, the interesting properties show up in situations where its not possible to measure a quantity and not plausible to bundle it up into a random variable using the central limit theorem. Sometimes you can, of course: in particular, this approach works well in modeling an quantum mechanic system which is already well modeled in classical physics. For the most part, we don't observe many quantum effects in day to day life! However, quantum mechanics is focused on the more interesting regions where those unmeasurable quantities have an important impact on the outcome of the system.
As an example, in many entanglement scenarios, you can get away with ignoring the correlation between the states of the particles. This is good, because in theory, there's some small level of entanglement between all particles that have interacted, and its good to know that we can often get away with ignoring this, and treating the values as simple independent and identically distributed variables. However, in the entanglement cases quantum mechanics are interested in, we intentionally explore situations where the entanglement is strong enough that that correlation can't just be handwaved away and still yield experimentally validated results. We are obliged to carry it through our equations if we want to provide a good model of reality.
There are many ways to do this, and one of the dividing lines regarding the topic is the line drawn between the different interpretations of QM. Some of them hold to a deterministic model, others hold to non-deterministic arguments (the Copenhagen interpretation being an example). In general, the models which are deterministic have to give up something else which is valued by physicists. The many-worlds theory gets away with being deterministic by arguing that every possible outcome of every classical observation occurs, in its own universe. This is consistent with the equations that we believe are a good model of quantum mechanics, but comes with strange side effects when applied to the larger world (quantum suicide, for instance). The Copenhagen interpretation is, in my opinion, the most natural interpretation in that it dovetails with the way we do classical physics smoothly, without any pesky alternate realities. I have found that mere mortals are most comfortable with the intuitive leaps of the Copenhagen interpretation, as compared to the intuitive leaps of other interpretations. However, the Copenhagen interpretation is decidedly non-deterministic. Because this one seems easier to explain to many people, it has achieved a great deal of notoriety, so its non-determinism gets applied to all of quantum mechanics via social mechanisms (which are far more complicated than any quantum mechanisms!)
So you can pick any interpretation you please. If you like determinism, there are plenty of options. However, one cannot use many of the basic tools of statistical mechanics to handle quantum scenarios because the basic physics of quantum mechanics leads to situations where the basic assumptions of statistical mechanics become untenable. Your example of the result of the measurement happening in the equipment is an excellent example. Like in statistical physics, the state of the measurement equipment can be modeled as a state vector, and it turns out that it's a very reasonable assumption to assume that it is randomly distributed. However, equipment designed to measure quantum effects is expressly designed to strongly correlate with the state of the particle under observation before measurement began. When the measurement is complete, the distribution of the state of the measurement equipment is decidedly poorly modeled as a state plus a perturbation with a small variance. The distribution is, instead, a very multimodal distribution, because it was correlated to the state of the particle, and most of the interesting measurements we want to take are those of a particle whose [unmeasured] state is well described by a multimodal distribution.
Cort Ammon
  • 53,814
  • 103
  • 176
Quantum mechanics is non deterministic of actual measurements even in a gedanken experiment because of the Heisenberg Uncertainty Principle, which in the operator representation appears as non commuting operators. It is a fundamental relation of quantum mechanics:
If you measure the position accurately, the momentum is completely undefined.
The interpretation of the solutions of Schrodinger's equation as predicting the behavior of matter depends on the postulates: the state function determined by the equation is a probability distribution for finding the system under observation with given energy and coordinates. This does not change if large ensembles are considered except computationally. The probabilistic nature will always be there as long as the theory is the same.
anna v
  • 236,935
Forget interpretations. The predictions of quantum mechanics - which agree with all interpretations (by definition of 'interpretation')- does not allow prediction of experimental/observational outcomes no matter how much information is gathered about initial conditions. (You can't even get the classical information needed in classical physics because of the uncertainty principle). None of the interpretations challenge this, not even in principle. According to the math, which is wildly successful in it's predictions, a given present does not determine the future. That's why quantum mechanics is said to be indeterministic, not because of any interpretation. It doesn't matter if you believe in wave function collapse or not or other worlds or not or whatever. Saying the theory is deterministic because of some math involved in the calculation isn't related to the fact that experimental outcomes cannot be predicted, The present does not determine the future.
If you learn Quantum Mechanics you will see that the observables of any quantum system depend on the state of the system(final, initial, ground state or excited state). In theory, there are a number of interpretations of Quantum Mechanics wiki, link.
The mathematical formulation of quantum mechanics is built onto the notions of an operators. When you do a measurement you perturb the system state by applying an operator on it. The eigenvalue of the operator corresponds to the measured value of the system observable. However, each eigenvalue have a certain probability, and therefore by measuring(applying) an operator on the state system there will be a finite(or infinite) number of final states, each of them with a given probability. This is the essence of non-deterministic in quantum mechanics.
The next question arises:how the non-deterministic applies on large scale universe and the "length" of the not-deterministic" phenomena in the universe?
Because in classical theory(like general relativity, electromagnetism), you have for example the Einstein equations which govern the dynamics and they are full deterministic.
Nikey Mike
  • 314
The quantum state of a system is completely characterized by a state vector only when the system is a pure state. The state vector evolves in two different ways described by two postulates: the Schrödinger postulate (valid when there is no measurements) and the measurement postulate. The Schrödinger postulate describes a deterministic and reversible evolution $U$. The measurement postulate describes a non-deterministic and irreversible evolution $R$.
$R$ is not derivable from $U$. In fact $R$ is incompatible with $U$, and that is the reason why the founder fathers introduced two evolution postulates in QM. Indeed, assuming an initial superposition of two states for the composite supersystem (system + apparatus + environment)
$$|\Psi\rangle = a |A\rangle + b |B\rangle $$
the result of a measurement is either $|A\rangle$ or $|B\rangle$, but because these states are orthogonal, they cannot both have evolved from a single initial state by a deterministic, unitary evolution, since that $|A\rangle = U |\Psi\rangle$ and $|B\rangle = U |\Psi\rangle$ implies $\langle A|B\rangle = \langle\Psi |U^{*} U | \Psi\rangle = 1$, which is incompatible with the requirement of ortohogonality.
So, if the result of the measurement was $|B\rangle$, the evolution was $|B\rangle = R |\Psi\rangle$.
juanrga
  • 5,853
-4
The fact that QM is probabilistic and not deterministic is forced by the 4 rules stated below. This rules can not coexist logically to provide determinism. They lead without effort to the probablistic interpretation.
Yes, unfortunately (for me) I am not a physicist. So take this with a grain of salt.
Some thinking about this puzzling issue will make you have these conclusions based on well-known facts:
@Quantum world:
1) Entities have a 'spread' existence. (A kind of 'field of energy' which tries to 'fill' all space).
2) Entities have some 'oscilatory' existence. (Which gives rise to 'interference' phenomena).
3) Interactions between entities are 'discrete'. (They exchange 'quanta' of somestuff).
4) Interactions use the 'minimum amount' of some 'energy stuff'.
The interplaying of these facts is what gives rise to the non-determinism (probability) in QM.
Let's think of a simple example:
Suppose you have 3 entities A, B and C (a 1 sender & 2 receivers scenario), where A is the source of some perturbation to be sent to B and C at the 'same time'. Let's think of the perturbation in practical terms (i.e.: money) and assign it a unit of measure (dollars).
Now how would A send 2 dollars total to both of them (B & C)?
Well, A should give them 1 dollar each and problem solved!!!. However, there is a constraint here (remember #4) and that is: Interactions are only done with minimun currency!!!'.
With that in mind, how can A give B and C one cent (minimun currency) at the same time? Well, .. It can't!!!
At each time (interaction) A must choose between B or C to give away every cent until completes the 2 dollars to both of them. And if you think a little bit about it, you realize that the only objective solution for A must be to throw an imaginary coin each time to decide whom will receive the 1 cent!. [Of course, for this 1 sender & 2 receivers situation, a coin with 2 faces fits rigth!. But for others scenarios, the coin or dice will have to change.]
In the analog world of classical mechanics, A would send an infinite small amount of money to both of them (no minimum currency constraint and at the same time!) and what we will see is a beautiful continuous growing of B and C money pockets. No need to deal with probabilities!!!!.
If you think carefully, in plain simple terms, probability arise from the discrete nature of interactions between entities. This is the real deal which turns everything so strange and interesting.
[Hope this general and somewhat vague answer gives you a clue about why probability arise in the description offered by QM]
The question now is: Why it has to be like that?
fante
  • 93
