The unit for angular acceleration $\alpha$ is:
$$\mathrm{rad/s^2}$$
The unit for torque is $\mathrm{Nm}$:
$$\mathrm{kg\ m^2/s^2}$$
And their relationship with Inertia is:
$$I = \tau/\alpha$$
So shouldn't the unit for for Inertia be:
$$\mathrm{kg\ m^2/rad}$$
yet everywhere I read says it is simply $\mathrm{kg\ m^2}$ instead. How does the $\mathrm{rad}$ unit fall off?
David Z
  • 77,804
See also Simple Harmonic Motion - What are the units for $\omega_0$? and https://en.wikipedia.org/wiki/Joule#Confusion_with_newton-metre
Here's a somewhat shorter explanation reflecting my own (possibly incorrect) intuition:
Radians aren't "real" units; they're just a trick to keep track of which quantities involve angles and which don't, since it's usually a mistake to get those mixed up. However, it's occasionally valid to mix those two types of quantities, and then we drop the radians. Torque is one such place.
It's probably possible to be fully rigorous about this and make radians an actual unit, but I've never seen it done.
