39
A similar question was asked here, but the answer didn't address the following, at least not in a way that I could understand.
Electric charge is simple - it's just a real scalar quantity. Ignoring units and possible quantization, you could write $q \in \mathbb{R}$. Combination of electric charges is just arithmetic addition: $ q_{net} = q_1 + q_2 $.
Now to color charge. Because there are three "components", I am tempted to conclude that color charges are members of $\mathbb{R}^3$. However, I've read that "red plus green plus blue equals colorless", which seems to rule out this idea. I can only think that either:
  • red, green and blue are not orthogonal, or
  • "colorless" doesn't mean zero color charge (unlikely), or
  • color charges don't combine in a simple way like vector addition
In formulating an answer, please consider that I know some mathematics (vectors, matrices, complex numbers, calculus) but almost nothing about symmetry groups or Lie algebras.
Hugh Allen
  • 1,635
Color charge is the representation of the SU(3) gauge group. The representation theory of SU(3) is described below:
The basic representation is called the "3" or the fundamental, or defining, representation. It is a triplet of complex numbers $V^i$, which transform under a 3 by 3 SU(3) matrix by getting multiplied by the matrix. The value of "i" is sometimes called "red","green","blue", so that a quark which is all in the $V^1$ direction is red, etc. This is reasonable, because every fundamental representation vector is a linear combination with complex coefficient of red-green-blue.
Hermann Weyl proved that every other representation occurs somewhere among the tensors: $V^{i_1,i_2 .. i_n}_{j_1,j_2,...,j_m}$ where the upper indices transform by multiplying the index by the SU(3) matrix, and lower indices by multiplying by the conjugate matrix, which is also the inverse. Addition of representations is just like addition of angular momentum in quantum mechanics, by taking tensor products.
Warm-up: Quick Representations SU(2)
For SU(2), the invariant tensors are $\delta^i_j$, $\epsilon_{ij}$, and $\epsilon^{ij}$, which are trace and two-dimensional volume. You can raise and lower indices using $\epsilon$ tensors, so every tensor representation is equivalent to one with all the indices down. Any three antisymmetric indices are necessarily zero, and any two antisymmetric indices can be deleted by contracting them with the appropriate epsilon tensor. So there are only clumps of symmetric indices in a representation.
The irreducible representations are exhausted by the fully symmetric tensors with all indices down:
$$ T_{i_1, i_2 , .... i_n}$$
Because when you multiply two of these, you get a tensor
$$ T_{i_1, i_2,....,i_n;j_1, j_2, ... j_n'}$$
with symmetry on permuting the first n indices and the last n' indices. I will write this as (n,n'). By contracting the $\epsilon$ tensor on one of the i's and one of the j's (they all give the same result because they are symmetric), you extract an (n-1,n'-1) representation from this. The remainder is fully symmetric on n+n' indices, because you have removed the antisymmetric part. The result is the decomposition
$$(n,n') = (n+n') + (n-1,n'-1)$$
So that, recursively, the tensor product of (n) and (n') decomposes into
$$(n+n'), (n+n'-2), (n+n'-4), ... (1) or (0)$$
where the last term is 1 if n+n' is odd, or 1 if n+n' is even. If you recognize that the n-index totally symmetric tensor with two possible values for each index has exactly n+1 different components, you realize that the (n) representation is just the spin (n/2) representation, and the decomposition above is the familiar Clebsch-Gordon series for addition of quantum angular momentum.
The tensorial method is never taught for some reason, but it is the quickest way to do Clebsch-Gordon decompositions in real life.
Back to SU(3)
SU(3) transformations preserve inner products, and 3-dimensional complex volumes, so there are three basic invariant tensors, $\delta^i_j$, $\epsilon_{ijk}$, and $\epsilon^{ijk}$. The $\epsilon$ tensors allow you to take the antisymmetric part on any two upper indices and turn it into a lower index, or the anyisymmetric part of two lower indices and turn it into an upper index.
The irreducible representations of SU(3) are all tensors
$$ T^{i_1,i_2,....,i_n}_{j_1,j_2,...,j_m}$$
which are fully symmetric on the upper indices, and fully symmetric on the lower indices. To see this, call this representation (n;m), and tensor two such representations to produce
$$(n,n';m,m')$$
Which means n totally symmetric upper indices followed by n' totally symmetric upper indices, and m totally symmetric lower indices followed by m' totally symmetric lower indices.
Then, acting the epsilon tensor between the n and n' clump produces
$$(n,n'; 1,m,m')$$
leaving behind $(n+n';m,m')$, since it takes away the antisymmetric part. The recursive rule is as ollows
$$(n_1,...,n_k; m_1,,...,m_k) \rightarrow $$ $$ (n_1+n_2,n_3,...,n_k;m_1,...,m_k) \oplus (n_1-1,n_2-1,n_3,...n_k; 1, m_1, ...,m_k)$$
$$(n_1,...,n_k; m_1,....,m_k) \rightarrow$$ $$ (n1,...,n_k; m_1+m_2,m_3,...,m_k) \oplus (1,n_1,...,n_k;m_1-1,m_2-1,...,m_k)$$
These rules correspond to acting with the two epsilon tensors, and they terminate on terms of the form (n;m) in a finite number of steps, because either thing on the right hand side either has a smaller number of clumps, or a smaller sum of indices. Decomposing the traces out of (n;m) gives all the irreducible representations.
Removing the traces
After you reduce the tensors to (n;m), you get rid of all the trace parts, by subtracting $\delta^i_j$ times an (n;m) tensor. This turns every (n,m) of the previous section into a series of trace-reduced (n-k;m-k) parts which go from k=0 to k=min(m,n). These tensors are the true irreducible representations.
The color charge is defined as the representation of SU(3) of the colored object. The representation is indexed by (n,m). The color-charge of an instance of the actual object is an n-list of rgb-rgb-..rgb values, where the order doesn't matter, and an m-list of cmy-cmy...-cmy colors, where the order doesn't matter. These are the basic colors, and you superpose them with arbitrary complex numbers, but imposing the trace condition, which is a little hard to state in RGB language--- it says that the sum of (r,LIST;c,LIST) + (g,LIST;m,LIST') + (b,LIST;y,LIST') is zero for any colors in LIST and LIST'.
To add two color charges, you use the procedure above for tensor products. The sum of two color charges is a complicated mixture of color-charges, given by decomposing the tensor representation.
These rules are relatively complicated, so be thankful that the only fundamental color representations in the world are quark fundamental triplets, and gluon one-up-index, one-down-index traceless tensors, and that all hadrons are singlets.
Here I would like to connect the tensor method given in Ron Maimon's nice answer with Young diagrams.
$SU(2)$
An irrep of the Lie group$^1$
$$SU(2)~=~\{M\in{\rm Mat}_{2\times 2}(\mathbb{C})\mid M^{\dagger}\eta M=\eta\wedge\det M =1\}$$
is classified by a weight $n\in\mathbb{N}_0$ and corresponds to a Young diagram with 1 row
$$\begin{align} (n)~=~&\underbrace{\begin{matrix} [~~]& [~~]& \ldots & [~~] \end{matrix}}_{n \text{ boxes}}\cr ~\cong~&\underbrace{(1)\odot(1)\odot\ldots\odot(1)}_{n \text{ factors}}~=~(1)^{\odot n},\end{align} $$
or equivalently, a totally symmetric tensor
$$T^{\alpha_1\ldots\alpha_n},$$
where each index $\alpha_1,\ldots,\alpha_n\in\{1,2\}$ belongs to the fundamental/defining/spinor representation
$$ (1)~=~[~~]~=~{\bf 2} .$$
The integer $n=2j\in\mathbb{N}_0$ is twice the spin $j\in\frac{1}{2}\mathbb{N}_0$. The character is
$$ \chi_n(q)~=~\frac{q^n-q^{-n}}{q-q^{-1}}~=~\sum_{m=0}^nq^{2m-n}. $$
The dimension is
$$ \dim (n)~=~ \chi_n(q\!=\!1)~=~n+1~=~2j+1. $$
The fusion rule is the well-known addition rule for spin
$$\begin{align} (n)\otimes (m) ~\cong~& \underbrace{(n)\odot (m)}_{\cong (n+m)}~~\oplus~~(n-1)\otimes (m-1)\cr ~\cong~& \bigoplus_{a=0}^{\min(n,m)}(n+m-2a) ,\end{align} $$
where the integer $a$ counts how many indices we antisymmetrize. Recall that the 2D antisymmetric Levi-Civita tensor $\epsilon^{\alpha_1\alpha_2}$
$$ \begin{matrix} [~~] \cr [~~]\end{matrix}~\cong~\cdot $$
corresponds to the trivial representation (=no boxes), which also explains why Young diagrams only have a single row.
$SU(3)$
$$SU(3)~=~\{M\in{\rm Mat}_{3\times 3}(\mathbb{C})\mid M^{\dagger}\eta M=\eta\wedge\det M =1\}$$
is classified by a weight $(n,\bar{n})\in\mathbb{N}_0^2$ and corresponds to a Young diagram with 2 rows
$$ (n,\bar{n})~=~\underbrace{\begin{matrix} [~~]& [~~]& \ldots & [~~] \cr [~~]& [~~]& \ldots & [~~] \end{matrix}}_{\bar{n} \text{ boxes}} ~~\underbrace{\begin{matrix} [~~]& [~~]& \ldots & [~~] \cr & & & \end{matrix}}_{n \text{ boxes}} $$
or equivalently, a tensor$^2$
$$T^{\alpha_1\ldots\alpha_n}_{\bar{\alpha}_1\ldots\bar{\alpha}_{\bar{n}}},$$
that is
  • symmetric in upper unbarred indices $\alpha_1,\ldots,\alpha_n\in\{1,2,3\}$ belonging to the fundamental/defining representation $$ (1,0)~=~[~~]~=~{\bf 3}; $$
  • symmetric in lower barred indices $\bar{\alpha}_1,\ldots,\bar{\alpha}_{\bar{n}}\in\{1,2,3\}$ belonging to the complex conjugate representation $$ (0,1)~=~\begin{matrix} [~~] \cr [~~]\end{matrix}~\cong~\bar{\bf 3}; $$
  • and such that all traces between upper and lower indices are removed.
Here
$$\begin{align}(n,0)~\cong~&(1,0)^{\odot n}\qquad \text{with}\qquad\dim (n,0)~=~\frac{(n+1)(n+2)}{2},\cr (0,\bar{n})~\cong~&(0,1)^{\odot \bar{n}}\qquad\text{with}\qquad \dim (0,\bar{n})~=~\frac{(\bar{n}+1)(\bar{n}+2)}{2}. \end{align}$$
Removing a trace leads to a recursion relation
$$ (n,0)\otimes (0,\bar{n})~\cong~(n,\bar{n})~~\oplus~~(n-1,0)\otimes (0,\bar{n}-1), $$
from which we can deduce the dimension
$$ \dim (n,\bar{n})~=~\frac{(n+\bar{n}+2)(n+1)(\bar{n}+1)}{2}. $$
The fusion rule is
$$\begin{align} (n,\bar{n})&\otimes (m,\bar{m})\cr ~\cong~& \bigoplus_{k=0}^{\min(n,\bar{m})}\bigoplus_{\bar{k}=0}^{\min(\bar{n},m)} (n-k,m-\bar{k};~\bar{n}-\bar{k},\bar{m}-k)\cr ~\cong~& \bigoplus_{k=0}^{\min(n,\bar{m})}\bigoplus_{\bar{k}=0}^{\min(\bar{n},m)}\left\{\bigoplus_{a=0}^{\min(n-k,m-\bar{k})} (n+m-k-\bar{k}-2a,~\bar{n}+\bar{m}-k-\bar{k}+a)\right.\cr ~\oplus~& \left.\bigoplus_{\bar{a}=1}^{\min(\bar{n}-\bar{k},\bar{m}-k)}(n+m-k-\bar{k}+\bar{a},~\bar{n}+\bar{m}-k-\bar{k}-2\bar{a})\right\}, \end{align}$$
where the integer $k$ ($\bar{k}$) counts the number of cross index contractions between the $n$ & $\bar{m}$ ($\bar{n}$ & $m$) blocks, respectively. The integer $a$ ($\bar{a}$) counts the number of antisymmetrizations of pairs of upper (lower) indices between the $n$ & $m$ ($\bar{n}$ & $\bar{m}$) blocks, which via the 3D antisymmetric Levi-Civita tensor is equivalent to a lower (an upper) index, respectively.
The fusion rule has the form of a Wick-type theorem written schematically as $$ (n,\bar{n})\otimes (m,\bar{m})~=~\bigoplus_{\text{allowed contractions}}:(\overline{\overline{n,\overline{\overline{\overline{\bar{n})\otimes (m}}},\bar{m}}}): $$ It is a sum of all allowed contractions of a normal-ordered expression
$$:(n,\bar{n})\otimes (m,\bar{m}): ~=~ (n+m,\bar{n}+\bar{m})~.$$
In particular the irrep
$$(n,\bar{n})~=~:(n,\bar{n}):$$
itself is already normal-ordered since all self-contractions (=traces) are zero by construction.
There is clearly an upper limits to how many contractions we can perform:
$$ k+a~\leq~ n, \qquad \bar{k}+\bar{a}~\leq~\bar{n},\qquad\bar{k}+a~\leq~m,\qquad k+\bar{a}\leq\bar{m}. $$
The resulting irrep is
$$(\ell,\bar{\ell})~=~(n+m-k-\bar{k}-2a+\bar{a},~\bar{n}+\bar{m}-k-\bar{k}+a-2\bar{a}).$$
The number of boxes becomes
$$\#(\Box)~=~\ell+2\bar{\ell} ~=~(n+2\bar{n})+(m+2\bar{m})-3(k+\bar{k}+\bar{a}).$$
Selection rule. Perhaps surprisingly, the integers $a$ and $\bar{a}$ in the fusion rule cannot simultaneously be non-zero, i.e. we cannot have both an upper and a lower antisymmetrization.
Tensor explanation: Given 2 tensors
$$T^{\alpha_1\ldots\alpha_n}_{\bar{\alpha}_1\ldots\bar{\alpha}_{\bar{n}}}\qquad\text{and}\qquad S^{\beta_1\ldots\beta_m}_{\bar{\beta}_1\ldots\bar{\beta}_{\bar{m}}},$$
operationally we assume that we have removed all cross-traces before any antisymmetrizations. Say the result
$$ R^{\alpha_1\ldots\alpha_r\beta_1\ldots\beta_s}_{\bar{\alpha}_1\ldots\bar{\alpha}_{\bar{r}}\bar{\beta}_1\ldots\bar{\beta}_{\bar{s}}}$$
has no cross-traces. Then an upper and lower antisymmetrization with 2 $\epsilon$-tensors
$$ R^{\alpha\alpha_2\ldots\alpha_r\beta\beta_2\ldots\beta_s}_{\bar{\alpha}\bar{\alpha}_2\ldots\bar{\alpha}_{\bar{r}}\bar{\beta}\bar{\beta}_2\ldots\bar{\beta}_{\bar{s}}} \epsilon_{\alpha\beta\gamma}\epsilon^{\bar{\alpha}\bar{\beta}\bar{\gamma}} ~=~ R^{\alpha\alpha_2\ldots\alpha_r\beta\beta_2\ldots\beta_s}_{\bar{\alpha}\bar{\alpha}_2\ldots\bar{\alpha}_{\bar{r}}\bar{\beta}\bar{\beta}_2\ldots\bar{\beta}_{\bar{s}}} \begin{vmatrix}\color{green}{\delta^{\bar{\alpha}}_{\alpha}}&\color{red}{\delta^{\bar{\alpha}}_{\beta}}&\delta^{\bar{\alpha}}_{\gamma}\cr \color{red}{\delta^{\bar{\beta}}_{\alpha}}&\color{green}{\delta^{\bar{\beta}}_{\beta}}&\delta^{\bar{\beta}}_{\gamma}\cr \delta^{\bar{\gamma}}_{\alpha}&\delta^{\bar{\gamma}}_{\beta}&\delta^{\bar{\gamma}}_{\gamma}\end{vmatrix}~=~0 $$
is zero. Note that each of the 6 terms in the above determinant must contain either a $\color{green}{\text{green}}$ or a $\color{red}{\text{red}}$ Kronecker delta. A $\color{green}{\text{green}}$ term vanishes because the tensors $T$ & $S$ are born traceless. A $\color{red}{\text{red}}$ term vanishes because $R$ has no cross-traces. $\Box$
Young tableau explanation: A resulting Young tableau $(\ell,\bar{\ell})$ is of the form [2]
$$\begin{matrix} [\leftarrow\bar{n}\rightarrow]&[\leftarrow n\rightarrow]&[\leftarrow a_1\rightarrow]&[\leftarrow b_1\rightarrow]\cr [\leftarrow\bar{n}\rightarrow]&[\leftarrow a_2\rightarrow]&[\leftarrow b_2\rightarrow]\cr [\leftarrow a_3\rightarrow]&[\leftarrow b_3\rightarrow]\end{matrix}$$
(not necessarily aligned), where
$$ a_1+a_2+a_3~=~m+\bar{m},\qquad b_1+b_2+b_3~=~\bar{m}. $$
Here $a_1$ denotes the number $a$'s in the 1st row, and so forth. The Littlewood-Richardson rules are [2]
  1. No same letter in the same column.
  2. When reading the extension in arabic order, one must demand that the number of $a$'s $\geq$ the number of $b$'s $\geq$ the number of $c$'s$\geq\ldots $ at any point while reading.
The 1st rule implies
$$\begin{align} a_2~\leq~& n,\cr a_3~\leq~&\bar{n},\cr a_3+b_3~\leq~&\bar{n}+a_2. \end{align} $$
The 2nd rule implies
$$\begin{align} b_1~=~&0,\cr b_2~\leq~&a_1 \quad\Leftrightarrow\quad a_2+a_3~\leq~m+b_3,\cr b_3~\leq~b_2+b_3~=~\bar{m}~\leq~& a_1+a_2 \quad\Leftrightarrow\quad a_3~\leq~m.\end{align} $$
One may check that this already implies weakly decreasing rowlengths of the resulting Young tableau $(\ell,\bar{\ell})$:
$$ a_2+b_2~\leq~n+a_1, \qquad a_3+b_3~\leq~\bar{n}+a_2+b_2. $$
We choose 3 independent variables: $a_2$, $a_3$ & $b_3$. We identify the number $\bar{k}=a_3\leq\min(m,\bar{n})$ of $(m,\bar{n})$ contractions.
  • Case $b_3\leq a_2:$ We identify the number $a=a_2-b_3\geq 0$ of $(n,m)$ antisymmetrizations; the number $\bar{a}=0$ of $(\bar{n},\bar{m})$ antisymmetrizations; and the number $k=b_3\leq\min(n,\bar{m})$ of $(n,\bar{m})$ contractions.
  • Case $a_2\leq b_3:$ We identify the number $a=0$ of $(n,m)$ antisymmetrizations; the number $\bar{a}=b_3-a_2\geq 0$ of $(\bar{n},\bar{m})$ antisymmetrizations; and the number $k=a_2\leq\min(n,\bar{m})$ of $(n,\bar{m})$ contractions.
It is straightforward to check that these identifications fit like a glove with the pertinent inequalities. $\Box$
References:
  1. S. Coleman, Fun with $SU(3)$, 1965; chapter 1.
  2. H. Georgi, Lie Algebras in Particle Physics, 2nd edition, 1999; sections 12.2 + 13.2.
  3. A. Zee, Group Theory in a Nutshell for Physicists, 2016; section V.2.
$^1$ We pick for simplicity the metric tensor $\eta$ equal to the Kronecker delta $\delta$.
$^2$ We have artificially lowered the bar indices. This is so that we can use a simplified calculus where we don't have to use a metric tensor $\eta$ when contracting unbarred and barred indices, and/or when using the Levi-Civita tensor. We leave it to the reader to properly restore the role of the metric tensor $\eta$. The main results will not change.
