Young diagram of shape $(a,b)$ has $a$ boxes in the 1st row, $b$ boxes in the second row.
Objective: decompose the following direct product of irreps, and then determine their dimensions given $SU(3)$
$$(3,1) \otimes (2,1).$$
I've determined this to be
$$(5,2) \oplus (3,1) \oplus (4,3) \oplus (2,2) \oplus (1) \oplus (4) \oplus (3,1).$$
I want to check that my dimensions are right (I'm having trouble with the inequivalence of irreps and their complex conjugates). I have
$$15 \otimes 8 = 42 \oplus 24^* \oplus 15_a \oplus 15_b \oplus 15_c \oplus 6^* \oplus 3$$
where the labels on the 15's denote inequivalent irreps and the *'s represent complex conjugates
Despite the whiff of doing your homework for you, and your having scrambled the order of the irreps so as to correspond their dimensionalities properly, yes, the answers are:
(2,1) ⊗ (3,1) = (5,2) ⊕ (3,1) ⊕ (4,3) ⊕ (2,2) ⊕ (1) ⊕ (4) ⊕ (3,1),
and, crucially, in their proper order, not your question's scrambled order, their dimensionalities unambiguously resulting from the hook rule and checkable by the arithmetic conservation of states (!) are
8 ⊗ 15 = 42 ⊕15 ⊕ 24$^*$⊕ 6$^*$⊕3 ⊕15 ⊕15 .
So, the only nontrivial equation is the first, resulting from distributing the 3 boxes, a,a,b, of the (2,1) onto (3,1). This *can only result in tableaux with 7,7-3=4, and 7-3-3=1 boxes, as you only chuck out 3-box towers--singlets.
This, then answers your question, about the conjugate reps: you cannot have a 6, so (2) with 2 boxes, or a 24, so (4,1) with 5 boxes. Moreover, note two of your 15s are of the original (3,1) type and the third one, the penultimate in this array, is a (4), instead. Analogously, you can never have a 15$^*$, so (3,2), as this has 5 boxes, an unachievable number in the Kronecker multiplication involved.
One might well wonder how you'd have lingering doubts and of what type they could be.
Cosmas Zachos
  • 67,623
An $SU(3)$ Young diagram with $a$ boxes in the 1st row and $b$ boxes in the second row corresponds to $SU(3)$ weights $(n,\bar{n})=(a\!-\!b,b)$.
To derive OP's $SU(3)$ fusion rules one can use a Wick-type theorem, explained in my Phys.SE answer here. The Wick-type calculus yields$^1$ $$\begin{align} {\bf 15}\otimes {\bf 8} ~=~&(2,1)\otimes (1,1)\cr\cr ~\cong~&:(2,1)\otimes (1,1): ~\oplus~:(\underline{2,1)\otimes (1},1): ~\oplus~:(2,\underline{1)\otimes (1,1}):\cr\cr ~\oplus~&:(\overline{2,1)\otimes (1,1}):~\oplus~:(\overline{\underline{2,1)\otimes (1},1}):\cr\cr ~\oplus~&:(2,\overline{1)\otimes (1},1): ~\oplus~:(\overline{2,\overline{1)\otimes (1},1}):\cr\cr ~=~&(3,2)~\oplus~(1,3)~\oplus~(4,0)~\oplus~(2,1)~\oplus~(0,2)~\oplus~(2,1)~\oplus~(1,0)\cr\cr ~=~&{\bf 42}~\oplus~\overline{\bf 24}~\oplus~{\bf 15}^{\prime}~\oplus~{\bf 15}~\oplus~\overline{\bf 6}~\oplus~{\bf 15}~\oplus~{\bf 3}. \end{align} $$
$^1$ The Wick-type theorem excludes a double antisymmetrization term
$$\begin{matrix} :(2,&1)\otimes (1,&1):\cr |&---| &\cr &|---&|\end{matrix} \quad~=~\quad (2,1)~=~{\bf 15}.$$
