12
With only a limited knowledge of general relativity, I usually explain space-time curvature (to myself and others) thus:
"If you throw a ball, it will move along a parabola. Initially its vertical speed will be high, then it will slow down, and then speed up again as it approaches the ground.
"In reality, the ball in moving in a straight line at constant velocity, but the space-time curvature created by the Earth's gravitation makes it appear as if the ball is moving in a curved line at varying velocity. Thus the curvature of space-time is very much visible."
Is this an accurate description, or is it complete nonsense?
anna v
  • 236,935
oz1cz
  • 223
5 Answers5
14
Yes, that's a fair description of what happens though of course from the ball's perspective it isn't moving - the rest of the universe is moving around it.
However statements like this, while true, give little feel for what's going on. Actually it's extraordinarily difficult to get an intuitive feel for the way spacetime curvature works (or at least I find it so!). The notorious rubber sheet analogy gives a fair description of the effect of spatial curvature, but neglects the curvature in the time coordinate and the time curvature is usually dominant since $dt$ gets multiplied by $c$ in the metric.
The motion of the ball is described by the geodesic equation, but a quick glance at the article I've linked will be enough to persuade you this is not an approach for the non-nerd. I have never seen an intuitive description of how the geodesic equation predicts the motion of a thrown ball.
John Rennie
  • 367,598
10
To me, the best way of describing it is as follows (semi-stolen from Carroll's Spacetime & Geometry): we all know from high school physics that, when no force acts on an object, it should not change its velocity $v$. In other words, the velocity vector tangent to the objects trajectory through space and time (i.e. world line) undergoes parallel transport. In flat space, that's just the same as keeping its Cartesian components constant. The equation corresponding to this expresses that the acceleration is zero (i.e. the velocity is constant): $$a^\mu=\frac{d^2 x^\mu}{d\tau^2}=\frac{d}{d\tau}\frac{dx^\mu}{d\tau}=\frac{d}{d\tau}v^\mu=0$$ (the upper index $\mu$ is just there to indicate the position and other vectors have four components, three corresponding to space and one to time: $t,x,y,z$ in cartesian coordinates. This comes from special relativity)
We would like to generalize this notion to curved spaces. Our idea is to have the velocity vector (the derivative of the position with respect to proper time) undergo parallel transport. However, parallel transport turns out to be trickier when spacetime is curved. We can no longer use 'simple' derivatives like we do in flat space, and have to emply what is called the covariant derivative, an introduction to which is probably not very enlightening if you're not familiar with the framework. Suffice it to say that this covariant derivative is the generalization of a normal derivative in curved spacetime. The more general notion of parallel transport (i.e. the curved spacetime version of 'keeping the velocity constant') which uses this covariant derivative gives rise to the equation $$\frac{d^2x^\mu}{d\tau^2}+\Gamma^\mu_{\rho\sigma}\frac{d x^\rho}{d\tau}\frac{d x^\sigma}{d\tau}=\frac{d}{d\tau}v^\mu+\Gamma^\mu_{\rho\sigma}v^\sigma v^\rho=0$$ The exact meaning of the second term is not so important if you're just trying to get a feel of what is going on. It is instructive, however, to compare the first equation with the second on. You see that the spacetime curvature gives rise to a second term which changes the way an object moves through spacetime. In flat space, coordinates can be chosen such that the second term reduces to zero everywhere in spacetime, recovering our original equation. The full expression is known as the geodesic equation, by the way, and objects with a worldline that obeys it are following a geodesic through spacetime.
Note that, during this explanation, we never referred to gravity as a force, but rather just assumed spacetime wasn't flat. This is, of course, a huge conceptual leap (and probably the source of many misconceptions and mistakes). In a very crooked sense, the motion of a test particle under gravity is 'straight', in that its 'velocity vector' is parallel transported, a notion which reduces to our intuitive idea of a straight line if spacetime is flat.
Danu
  • 16,576
  • 71
  • 110
I'll raise some issues. Firstly you say
In reality...
Do you contrast something against something else here? It implies you say there the preceding sentence
If you throw a ball, it will move along a parabola. Initially its vertical speed will be high, then it will slow down, and then speed up again...
wasn't right, but that sentence seems pretty resonable. The problem is that there are many perspectives/frame to describe the world and all are valid. In particularly you then say
but that's of course just as relative. If that's true, how is the above sentence not true? In curved spacetime, you can't pic a global inertial spacetime, so I'd not refer to right and wrong velocities in the elaborations.
Now in general relativity, and that's what Danus answer is in particular about, you use another language to specify what straightness is, the mathematical language of Riemannian geometry, and the expressive power of the formulas doesn't really fit into two englisch sentences. The
straight line
sections of your explanation is problematic. Because, of course, if you already know Riemannian geometry, you read "straight line" as "solution of the Geodesic equation", but the people who you explain relativity to will not. It's a little like if you don't catch sarcasm. While hearing it, you might understand the words perfectly well but when you come back to think about, what has been said doesn't quite add up.
...but the space-time curvature created by the Earth's gravitation...
Do you have a working definition of "Earth's gravitation"? Because to me it's the space-time curvature around it.
...makes it appear as if the ball is moving in a curved line at varying velocity.
Same velocity-problem as above. Keep in mind that there are frames where your left eyeball is rotating around your nose, and there are frames where your nose is rotating around your mouth.
Nikolaj-K
  • 8,873
You have the right basic idea. But it gets simpler to visualize if you just drop the ball, or throw it vertically. Then there is just one spatial dimension to consider, and you can directly compare the paths in space and in space-time, like shown here:
http://www.youtube.com/watch?v=DdC0QN6f3G4
But note that this doesn't involve any intrinsic space-time curvature. Such curvature is related to tidal effects (geodesic deviation), which are negligible over small distances (like the height of an apple tree or a ball throw). However, over larger distances intrinsic curvature is inevitable, as shown in the last link of the video description:
http://www.adamtoons.de/physics/gravitation.swf
Is this an accurate description, or is it complete nonsense? "If you throw a ball, it will move along a parabola. Initially its vertical speed will be high, then it will slow down, and then speed up again as it approaches the ground.
More accurately:
The ground (as well as anything rigidly "connected to the ground") would move along a parabola wrt. the "thrown ball", or rather: wrt. the entire "freely moving inertial system" (such as a "falling ruler") of which the ball is one member.
The difference is that the members of a (suitable) inertial system are (at least to some approximation) at rest to each other; accordingly they are capable of determining distances as well as simultaneity relations between each other, and in these terms they may describe the trajectories of other participants who the met in passing (such as elements of "the ground", or for instance the hands/fingers which are typically shown in the pictures alongside the "falling rulers", moving along parabolas).
In contrast, the geometric relations of elements of "the ground" and other participants (especially: "above" or "below") are more complicated; they are (at best) rigid to each other, i.e. their mutual relations are not characterized by distances but by quasi-distances, and they fail at determining simultaneity of their indications. Accordingly, it would be inaccurate to say that they could determine and express the trajectories of those participants who they met in passing (such as a "thrown ball", or the ends of a "falling ruler") as a definite parabola.
The "thrown ball" is at rest wrt. suitable other participants;
  • either exactly, in a flat region,
  • or at least to some accuracy (and: "the closer, the more accurate") otherwise.
user12262
  • 4,360
