I know that I have to clip my cat's nails every now and again, and that got me wondering about my sister's rabbit - does its nails have to be clipped as well? Can we use the same style of nail clippers on the rabbit as she has for her cat?
For reference, the cat's nail clippers look like this:
Zaralynda
  • 20,276
  • 15
  • 78
  • 150
A rabbits nails will wear down if there are appropriate surfaces and activities available, such as digging holes, to enable that. Without that, which is generally pretty much the case for all house rabbits, you do need to maintain them yourself.
Generally, the easiest way to do this is the bunny burrito (wrap them in a nice towel to hold them) and clip using the cat clippers you show, these are perfectly fine. Press gently on the foot pads to expose the nail and be very careful to avoid clipping the quick. It's probably a wise idea to have some styptic handy such as Kwik Stop, just in case you do, that will stop any bleeding fast.
Take your time with this. The bunny isn't going to like it, but if you do it regularly and get it used to it, then it gets easier. Ours hated it, but it's necessary, so don't give up on it.
Joanne C
  • 20,389
  • 59
  • 104
Yes, this is necessary for house rabbits. Not trimming a rabbit's toenails can cause sore hocks, where the fur on the hocks gets raw and sore and in an extreme case infected. If your rabbit does have sore hocks, make sure it doesn't sit on cage wire all day. I've used drywall but some experienced caretakers caution against materials present, per comment kiln-dried pine wood or white wood is good. Cardboard will not hold up.
Re. clippers, yes, the same will probably work. But just some "common sense"-type advice:
  • the clippers should be comfortable for you. Even if cat clippers work fine, you may find them too big, for instance.
  • any clippers can become dull. If the cut is not clean - i.e. the blade goes past the nail, then it tears forming something like a hangnail - that's bad. You'll need to replace the blades or clippers (or sharpen the blades if you can figure that out.)
As for clipping nails in general, for light-furred rabbits it's usually easy, as much like human finger nails you'll be able to see very clearly where the blood starts. Clip above that, try not to get any fur, you're done.
For darker furred rabbits there's a good chance you'll be able to see anyway. Good light will help. Otherwise, in the worst case you may have to use some estimation and guess work. Rabbit nails shouldn't really curve (if they look like talons they are way too long), so you can cut off the curve or sharp point. You'll try to get an intuition for the thickness of the real part of the nail.
Obviously this bit about guesswork if you can't fully see where to cut is uncomfortable. Yes, bleeding may occur. This is obviously undesirable but straightforward to deal with - you should have a clotter, such as cornstarch or a commercial formula, on hand.
Lastly, front feet have 5 nails each (4 + a thumb), back feet have 4 nails each. Cavies are 4 front, 3 back, for reference.
djechlin
  • 281
