10
I just got my first "big boy" job at the tender age of... 34, after a long time in academia and a startup stint that worked out pretty well (startup got acquired by public company) - so now it's the first time I have the option to contribute to an employer-matched 401k. There is a good selection of Vanguard funds (both target-date and mutual funds) and the default selection is the target-date 2045 fund. Since I am starting late, I only have a few thousand dollars stashed away in a Roth IRA with no other retirement savings, and I am planning to aggressively fund the 401k in order to catch up.
Do you recommend I just allocate 100% to the 2045 fund, choose the 2050 fund instead (I understand that it takes a while longer before it starts switching to more conservative selections) or add a percentage of VFINX too? (10-20% of my allocation?)
nvergos
  • 213
Vanguard starts to adjust the weightings at 25 years out, so you're certainly right that VTIVX will soon start to be a little less aggressive (in 2020). It's not going to go drastically conservative, just a little less aggressive; from 90/10 to 80/20, perhaps. So VFIFX would be more aggressive (90/10) for a little longer (until 2025).
On the other hand, the question is really when do you plan to retire? There's a reason that Vanguard starts adjusting things when they do; it's because you want a bit more stability and less likelihood of taking a huge loss that you won't have time to make up. Admittedly 25 years out seems far to be doing that, but still. Sure you need to grow your retirement fund as quickly as you can, but more growth equals more risk, and if you're already light, you're not exactly going to have a lot that you can afford to lose, will you?
If you don't have enough saved, and you know you don't have enough saved, you may want to accept that you have two major choices: put more in the 401k, enough that you catch up to where you needed to have been at this point, or put off your retirement date a few years. At which point VFIFX is simply accurate rather than aggressive.
Joe
  • 35,939
  • 92
  • 129
