Nissan Frontier 2018 4.0L. SV Parts store said I could use any washer in an assorted pack of washers labeled M14. Upon looking further into issue I found that a M12 is the correct size. I already installed the M14. It is not leaking now. Will that be OK until next oil change? Or change it now.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
steve lay
  • 51
My "opinion" is, you should change it now. If it's too big, even if sealed now, will want to allow the bolt to loosen up at some point. Whether it gets loose enough for the bolt to fall out or just loose enough for it to start leaking, neither thing is good. If it were me, I'd get it changed.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
