Today I was driving my BF's 2003 Nissan Frontier when suddenly it dies. No power, everything died. No hazard lights either. I tried popping the clutch to get it started and nothing.
I parked it in median and raised the hood. The battery was just replaced so I checked the connections and all was fine. I looked through the wiring and all seemed fine. About an hour goes by and then I hear the hazards come on so I decide to try to start the truck.
It turns over no problem so I drive it home, no problems whatsoever. I ask my BF to take me to the train. Enroute driving, he turns on the headlights and boom, it did it again.
He tried popping the clutch and it wouldn’t turn over. Just bog no power at all so we coasted off freeway and parked it. It has been over an hour and still no power. If anyone has any ideas I would be very grateful because I’m at a loss.
It sounds electrical to me but maybe it could just be the alternator and battery. It’s a new battery so I don’t know any ideas. I’m open ears.
DavidRecallsMonica
  • 3,685
  • 19
  • 31
It sounds like you have a loose main ground. As the vehicle heats up the bolt expands and the connection gets weak, then the vehicle shuts off. Follow the ground wire from the battery and ensure the frame location it bolts to is indeed tight. Also make sure the battery connections are clean and tight.
Mr. Anderson
  • 297
