I've had P2002 error code on my Ford Mondeo MK4 2010 2.0tdci for a couple of months now and I can't find the fault. It's been to the mechanics and had new dfp hoses, a manual regeneration, a good run down the motorway and finally a new DPF fitted but everytime I get the error code taken off, it comes back on within 20 miles of use. The car is running fine and just passed its MOT. Any suggestions as to what to try next? This is becoming expensive.
T.dew
It has to be something with the DPF. Most common cause for this error are broken hoses going to the differential pressure sensor. Another thing might be broken sensor itself or the wiring going to it. But you are saying that whole DPF was changed, did it include the change of the sensor as well? Also double check the hoses, maybe they still leak somewhere.
Mark
  • 441
