I have a Madza Scrum/ Suzuki curry small truck which is boiling whenever i travell just 5 kilometers, please help what might be the problem
Asked
Active
Viewed 59 times
I've had this problem with both a car and a motorcycle in the past. In both cases the problem was a seized thermostat.
Here is some more info on testing your thermostat: How can I test my thermostat?
If the thermostat is the problem, I'd recommend replacing it, but gutting it is also an option,
Hope this helps.
Willem
- 249
- 2
- 10
You can remove and test the thermostat to ensure it's opening at the right temp. A bad radiator/cap/blockage could also be causing a problem. That could include air in the system if it needs to be bled out in a special manor.
At worst, it could be a head/gasket problem which you can get a test for from most local autopart stores.
BillyBob
- 21
- 1
