Background
My 2009 V8 LR3 has done around 150k km. It has a permanent 4WD system.
I have no record of prior drivetrain-related maintenance.
Question
If I have to prioritize which diff's fluid to replace first (due to wear and tear), which one should it be?
Should it be:
  • the rear diff, as it is always transmitting torque to the wheels from the engine, or
  • the front diff, since it is sees more difference in rotational speed across the two output shafts (induced by steering), or
  • both, because diff fluid degradation is related to other causes?
Zaid
  • 39,276
  • 50
  • 151
  • 294
All three - front, back and transfer box/centre diff. As it's a permanent 4WD system, all three diffs are in constant use, so if you've got no record of them being changed, it's probably worth doing all of them.
Saying that, what does the service schedule recommend?
I can't remember if the Discovery 3 still has traditional 'swivels' on the front axle, but if it does, I'd also recommend at least checking the oil/grease level in those.
Edit - I've just found that my local Land Rover specialist has a guide to servicing on their website:
Keith Gott Service Schedule
Key points here are:
60 months/ 75k miles:
  • Renew transfer box oil, replace drain and fill plug washers
  • Renew locking differential oil
120 months / 150k miles:
  • Renew manual gearbox oil
  • Renew automatic transmission oil and filter
  • Renew front and rear axle oil
So at roughly 93k miles, you don't actually need to do the axles yet, but you should do the transfer box and centre diff if it hasn't been done.
Nick C
  • 28,941
  • 56
  • 109
