How can I troubleshoot a code U0208 on a 2009 Land Rover LR2? It has a 3.2L engine. Thanks!
Asked
Active
Viewed 809 times
I found this resource by searching on the terms "u0208 land rover." The linked document provides a step-by-step troubleshooting procedure. Try working through it and post a more specific question if you get stuck.
Somethings to keep in mind / look for:
Assume that it is a single problem until you've exhausted that option.
Check the fuse.
Look for corroded connections, signs of water/liquid getting near the controller and its connectors.
Look for physical damage to the wires serving the controller, the seat, and the door (for the mirror).
See if there are any other codes set (see the procedure notes).
dlu
- 14,506
- 8
- 52
- 85
