Opened the bonnet, looked to LHS beyond screen-wash reservoir, removed cap on (?) hydraulic oil, found it to be RED in colour and below minimum level when engine not running.
Went to shop: insisted I buy hydraulic oil for manual - GREENish in colour! Panicked. Went to another shop: bought hydraulic oil for automatic - RED in colour.
Confused!
  1. Can I mix manual and automatic hydraulic oil?
  2. Low/dry reservoir - does it greatly damage clutch?
dlu
  • 14,506
  • 52
  • 85
clint mede
  • 241
It sounds like you opened the power steering reservoir. If so, these usually use the same red dexron fluid as automatic transmissions.
Usually there is a symbol on the cap to identify it. Quite often the power steering has a steering wheel symbol. You really need to know exactly what to put in before you add anything.
HandyHowie
  • 25,681
  • 40
  • 76
Look in the owners manual (if you don't have it, check online there may be a PDF version available). That should both tell you what the various reservoirs are for and what is supposed to go in them.
dlu
  • 14,506
  • 52
  • 85
