This is similar to, but not the same as my question Effects of Dirty Piston Heads and Intake Valves.
Basically, I often see people talking about taking the intake manifolds off older cars to clean them, or to seafoam them, separate from just trying to get the valves clean.
However, I would think that unless there is a major problem with the engine which has caused a truely massive buildup of gunk then a typically dirty intake manifold shouldn't really be much of an issue.
The only things I could think of would be that maybe a dirty intake could throw off ECU fuel calculations relating to the assumed Tau pool on the intake walls, but that would seem to be a pretty small effect I would think.
The other thing I could think of might be clogged EGR passages, but I don't think seafoaming would help with that.
Anyways, what are the effects of a typically dirty intake manifold?
Robert S. Barnes
  • 15,780
  • 72
  • 157
  • 249
Upstream the throttle body
A dirty intake by itself isn't the problem, but it is a sign of contamination of related components:
  • MAF sensors don't take kindly to dirt
    This will usually lead to the fouling of the hot-wire(s), resulting in the underreading of air mass flow, which will lead to positive fuel trim correction.
    If the contamination is bad enough, the engine will feel sluggish and slow to respond.
  • Throttle plate actuation can be hindered
    Crud tends to build up on the back of throttle bodies. If bad enough, they will hinder the ability for the actuation of the throttle plate, which can lead to driveability problems.
  • A clogged EGR hose/valve can throw off fuel management
    Again, this will show up in fuel trims, albeit not dramatically. The obvious thing to suffer from lack of EGR will be the environment due to increased NOx emissions.
Downstream the throttle body
The only losses between the throttle body and intake valves will be caused by ductwork.
In almost all situations, the deposits of oil, fuel and dirt will not have a significant impact on pressure drop. I'd expect the performance gains from cleaning this part of the manifold to be minimal.
Of course, the lesser the dirt that goes past the intake valve, the better.
However, the right solution is to ensure that dirt doesn't enter in the first place: Keep the intake tract air-tight and use a good quality air filter.
Zaid
  • 39,276
  • 50
  • 151
  • 294
