I'm working on a 98 Mazda 626 GF 2L with an automatic transmission. While I'm used to driving manuals, I would say that the amount of vibration when sitting stopped in drive with the brake on seems excessive. The excess vibration goes away when put in neutral. I also noticed that when first taking off or in certain types of acceleration it feels mushy, like there is a lack of power until suddenly I get a solid feeling. All this is in addition to a rough but stable idle when in park.
The tranny fluid is pretty old and dark ( it hasn't been changed for five years and about 80,000 kilometers ), however it's not dirty - there is no grime or particles in the fluid and there is no burnt smell ( I asked more than one person to smell it ). Also, the gears engage immediately without hesitation when I shift it into drive or reverse.
Due to this I don't think it's the clutches. While I have little exp. with automatics, my gut feeling is that the torque converter maybe isn't working as efficiently as it should and isn't locking as soon as it should. I think when it finally feels solid and powerful that is the torque converter locking.
If I'm correct about the nature of the problem, could changing the old fluid out and adding something like lucas transmission fix improve the situation? Or do those types of products only help with worn clutches?
If that won't help, how big of a job is it to change a torque converter and is it an expensive part?
EDIT
Another thing to consider, could this just be a symptom of problems with the engine idle? When in park and I press hard on the gas the engine seems to wobble / shake and if I go to WOT it's very noticeable and I'll even hear a belt slip for a moment.
EDIT 5/1/2016
OK, so after putting in a new Lambda, valve cover gasket and plugs, things are much better, however I still feel like there is excess vibration and I think there might be more than one cause.
The problem is worst when I first start the car, and gets progressively better as everything warms up. When everything is cold, and I switch into D, the vibrations are very pronounced. Once both the engine and tranny are warmed up the vibes are much less noticeable. The thing is that once warm and I switch into drive there is a momentary drop in rpm from about 700 to 500, during which there's allot of vibrations, then once the rpm recovers the vibes kind of smooths out, but don't go away completely.
Some thing that might be relevant:
  • there is no noise accompanying these vibrations
  • the vibrations go away the moment the car starts moving
  • I can downshift while driving and hit the gas and it responds immediately
  • generally the tranny seems to be performing pretty well
  • I noticed that the engine itself seems to be vibrating more than I would expect at idle
  • one of the engine mounts looks pretty beat up ( I'll put up a pic later )
  • the ATF is dark and heavily oxidized, but still clean
Sooooo, I'm thinking maybe changing the ATF and fixing the motor mount might solve the problem.
EDIT 6/1/2016
Here's that pic of the engine mount. I figure being able to stick my finger through it is a problem:
This is what a new one is supposed to look like:
EDIT 6/1/2016
So I changed the ATF and that doesn't seem to have made a difference.
Robert S. Barnes
  • 15,780
  • 72
  • 157
  • 249
I would check the motor mounts sounds like your may have a cracked one but it could also be that you have a vacuum check valve attached to your Power Brake Booster that has gotten old and needs replacement, or there may be a vacuum leak elswhere check your vacuum hoses.
Sam Rosario
  • 388
