20
Let's suppose Person A gets injured by Person B and says, "He attacked me for no reason and injured me." Person B says, "Yes, I injured Person A, but I was attacked by him for no reason and just defended myself." There are no witnesses, so all you have is the fact that Person A was injured by Person B, along with their respective accounts.
If both accounts are equally credible, will Person B be deemed guilty because he can't prove it was self-defence, or will Person B be acquitted because the prosecution can't prove it wasn't self-defence?
I'm a layperson when it comes to legal matters and am curious about the legal implications of self-defence. Do most jurisdictions follow the same principle, or are there fundamental differences in terms of who has to prove what?
feetwet
  • 22,409
  • 13
  • 92
  • 189
Mitsuko
  • 303
The burden of proof in self-defence cases follows the general principles set out in Woolmington v DPP [1935]. This clarified that:
  1. the prosecution must prove the defendant’s guilt beyond reasonable doubt​
  2. the defendant does not need to prove self-defence, but the defence is only applicable if they are able to raise some evidence suggesting that it is a live issue​.
  3. once self-defence is raised, the prosecution must disprove it beyond reasonable doubt​
If the jury is left in doubt about whether the force used was reasonable, the defendant must be acquitted.
Applying this to your hypothetical: If both Person A and Person B are equally credible and there are no witnesses, then the prosecution has not proved beyond reasonable doubt that Person B acted unlawfully. Person B does not need to prove self-defence, only raise it as a possibility. If the prosecution cannot disprove self-defence beyond reasonable doubt, Person B should be acquitted.
Most common law countries follow the above or something very similar to the above (although be sure to check as not all do).
FD_bfa
  • 6,468
  • 80
21
The accused must establish an air of reality to the defence
For self defence to even be left with the jury or fact-finder, the accused must first establish an "air of reality" to the defence. The accused must point to some evidence, upon which, if believed, a properly instructed jury acting reasonably could acquit. This is a mere evidential burden on the accused and it is low.
Then the Crown has the burden of disproving the defence beyond a reasonable doubt
If the accused establishes an air of reality to self defence, then self defence becomes part of what the Crown must negate beyond a reasonable doubt. The Crown must show beyond a reasonable doubt either that:
  • the accused did not believe on reasonable grounds that force or threat of force was being directed at them; or
  • the accused did not act with the purpose of defending themself; or
  • the act said to be in defence was not reasonable in the circumstances.
See: R. v. Cinous, 2002 SCC 29; R. v. Khill, 2021 SCC 37.
Jen
  • 87,647
  • 181
  • 381
Some U.S. states, including Ohio, until 2019 historically required that self-defense be proved as an affirmative defense by a preponderance of the evidence. At this point, however, all U.S. states require that it be ruled out beyond a reasonable doubt by the prosecution at trial if facts raising the issue are presented, although some states allow for the case to be dismissed prior to trial if this affirmative defense can be established in an evidentiary hearing before a judge by a preponderance of the evidence.
In the end analysis, this changed when Ohio changed its rule in 2019, but there is still a role for the preponderance of the evidence rule, which continues to apply in many states as the standard required to dismiss a case on self-defense grounds prior to trial, as explained at the link:
[H]istorically, the affirmative defense has shifted the burden of proof. Normally, the burden of proof is on the accuser–the state or the plaintiff–to show that a wrong was done by the defendant. Here, the defendant has said, “Yeah, I did the thing you say was wrong. I’m saying I was right to do it, and therefore should be held harmless.”
I always invoke the balance test from two great legal scholars, in my opinion, one being, Henry Campbell Black. He was the author of Black’s Law Dictionary which is still the standard today. If you look up “affirmative defense” in Black’s Law Dictionary it will clearly state, the affirmative defense shifts the burden of proof to the defendant.
Now, the other citation is from a man I consider a great legal scholar of our time on this topic, Andrew Branca, author of Law of Self-Defense. When Andrew meticulously went through the laws and the rules of the courts in all 50 states, he found what I did way back in the ‘70s, when I did that for my first book, In The Gravest Extreme that came out in 1980.
What the law says is that once self defense is on the table and the jury is allowed to hear the argument or the judge accepts that it is a possibility, at that point in a criminal case the burden of proof shifts back to the state to prove that it was not self defense. The one exception for many, many years was the state of Ohio, which said in the black letter law in a self-defense homicide or a self-defense harmful action the burden would be upon the defendant to show that it was self defense. . . .
A quick commentary on the standards of proof may help. A guilty verdict demands that you be found guilty beyond a reasonable doubt. When self defense is on the table, the standard of proof is to a preponderance of evidence to show that it was self defense. That remains the standard today in some of the states that have the so-called stand your ground option. That is a misnomer: really, it is simply a pre-trial hearing in which the judge determines whether or not there is enough evidence to show that you are likely to be guilty. If in that hearing, you can show to a preponderance of evidence–more likely than not–that it was self defense, in those states the judge has the power to permanently dismiss the case, dismiss it with prejudice, and end it right there.
Let’s go back: so, if we have self defense on the table, where is the burden of proof? For self defense to be on the table at all–for the judge to allow your attorney to say “self” and “defense” in the same sentence–prior to trial, you will have to show some corroboration that you are not just saying, “Take my word for it! It was self defense.” The required corroboration is called “burden of production.” When I hear “burden of production,” to me the operative term is “burden.” In and of itself, right there, it is a burden of proof element from the get-go. Once self defense is on the table, the judge is going to tell the jury that the prosecution has to prove beyond a reasonable doubt that it was not self defense.
Then, as the instructions go to the jury, and as the door closes on that deliberation room theoretically, at law, the burden is back on the opposing side, on the prosecution.
Note also, that any U.S. state could return to Ohio's pre-2019 rule that a defendant has to prove self-defense by a preponderance of the evidence at trial in the future. There is no national rule of constitutional law on this point. The change in Ohio's rule was due to a new criminal procedure statute and not a court holding that its old rule, which applied for many, many decades to countless cases without falling to a constitutional challenge, was unconstitutional.
ohwilleke
  • 257,510
  • 16
  • 506
  • 896
Not a lawyer here, but this is what makes the law so damned interesting to us lay people.
ohwilleke gives a comprehensive answer to what the general law is in the US. Great. However, the states and prosecutors apply this law very differently. For example on one end of the spectrum you have the Polk County Sherriff who encourages his citizens to shoot and kill home invaders and looters. He is saying that his department will not even charge home owners who do such with a crime. So really only that self-defense was suspected for property crimes.
Then on the other end of the spectrum you have Manhattan. Some dude was minding his own business, doing his job, was attacked and shot by twice by a robber. He wrestled the gun away from the robber and shot this person. The cops charged that dude with murder despite it being obvious self-defense. He did not carry the gun to the fight, the only reason it was involved was because the robber brought it to the scene. The victim here was only fighting for his life!
He was arrested and spent time in jail. Probably had to hire a lawyer. While the charges were eventually dropped, it did take some time and public pressure to do so. So basically the same framework of laws but two very different attitudes of the applications of those laws.
Pete B.
  • 1,164
  • 20
