I need to convert a 4 V peak to peak signal (-2 V to +2 V) into a 0 to 3.3 V signal to get it into my ADC on LPC 11u24. I have tried several designs but the problem is that all of the designs I found are based on single rail op amps. I only have dual supply op amps. Any suggestions?
Based on this post, a summing amplifier could work. Adjusting the values, the schematic would be as follows:
The output is calculated just like a non-inverting amplifier. Thus, when the sine wave is +2V, the terminals of the op-amp are at 2V. Since
\$V_O = V_I(1+\frac{R_4}{R_3})\$
the output will be 3.3V. When the sine wave is -2V, the terminals will be 0V, since the two voltage sources, \$R_1\$, and \$R_2\$ act as a voltage divider. Then the output will also be 0V.
The caveat here is that you need a rail to rail op-amp, or supply voltages that are less than 0V and greater than 3.3V. Otherwise the op-amp will clip the output.
- 1,617
- 1
- 14
- 19
There are also simpler, passive solutions here: http://electronics.stackexchange.com/questions/32318/how-can-i-measure-voltage-in-range-15v-to-50v-with-adc-in-microcontroller-in-a/32328#32328, http://electronics.stackexchange.com/questions/7583/how-do-i-sample-a-2-v-to-2-v-analog-signal-with-a-pic-microcontroller – Justin Trzeciak Jan 31 '14 at 13:06
This will level shift your +/-1V signal, however it requires a low impedance source and you lose a couple (1.7) bits of resolution.
- 397,265
- 22
- 337
- 893
The network above gives you a -3.3 to 3.3V range (6.6V p-p) as your signal is only 2V p-p, you lose $log_2$(3.3) bits. – Spehro Pefhany Jan 30 '14 at 18:03
Use a non inverting amplifier with gain as 1.65.
This link could help you (http://www.instructables.com/id/Non-inverting-amplifier-with-uA741/?ALLSTEPS)
- 119
- 5
I only have dual supply op ampsWhy is that a problem preventing you from using the solutions you found for single rail opamps? – alexan_e Jan 30 '14 at 18:26
