I am working on oscillators at the moment and need clarification. So far, I understand that the barkhausan criteria determines if the oscillator will oscillate or not. The rules are: 1)make the loop gain, gain of feedback network times gain of amplifier, 1. 2)Make the phase angle around the loop 0 degrees. To me, these two rules are used to determine the formula for oscillation frequency, which is necessary. However, this says nothing about the mechanism used to stabilize the gain.
Upon further investigation, I found that the poles of the loop gain need to move to the right half plan to start oscillation and a non-linear amplitude stabilization mechanism pulls the poles back to the imaginary axis. I don't understand how this works. Do the right half-plane poles mean that the gain is greater than 1 (positive feedback), left half plane poles mean the gain is less than 1 (negative feedback) and the imaginary axis indicates unity gain?
