Usually the chassis of any household equipment is connected to earth ground for safety.
Part of the culprit is neutral being connected to Earth ground. (Reasons are mentioned in this post.)
My question is for an aircraft power supply (115V/400Hz AC), why is the neutral not connected to chassis GND? (In fact, the standard specifies strict isolation between the power lines and chassis GND.)
  • What is the real consideration for it being different from utility power supply?
  • Is it for safety reasons?
Image source
JRE
  • 71,321
  • 107
  • 188
Dynamic_equilibrium
  • 3,008
  • 20
  • 38
  • Are you talking about the same thing? The regular mains power supply input looks the same as your aircraft supply, neutral and earth are not connected on the power supply end but at the distribution box end. – Justme Nov 09 '23 at 05:34
  • The neutral and earth are connected 'somehow' in utility power supply whereas the two are completely isolated in aircraft power supply. – Dynamic_equilibrium Nov 09 '23 at 05:43
  • Probably the same reason as ships. No real ground. If you lose power in the air, what is likely to happen? – StainlessSteelRat Nov 09 '23 at 05:48
  • If so, how does the linked article or picture relates to the question? The picure and article are about power supplies to make e.g. 5V, not picture or article about aircraft earthing or generators? – Justme Nov 09 '23 at 05:50
  • @Justme: The image source link talks about Aircraft power (aircraft 400 Hz electrical source). Sorry, I could nt find a better image on Aircraft power supply circuit. – Dynamic_equilibrium Nov 09 '23 at 05:55
  • It's an IT-net (Isolé Terre). – S_G Nov 09 '23 at 07:07
This is typical in aircraft installations and for a few reasons. Firstly, if the supply is truly floating then any single fault that connects either live or neutral to chassis won’t cause a problem. Secondly, aircraft structures aren’t designed to carry any significant current (unlike automotive electrics) so a formal return conductor is always provided. Isolating this from the chassis ensures that there’s no current through the airframe. This helps to isolate different circuits so that a fault in one circuit won’t cause a failure in another.
Frog
  • 7,287
  • 13
  • Utility power system (AC) : Line, neutral -> Carries current, Neutral at Earth potential
  • Aircraft power system (AC): Line, neutral ->Carries current, Neutral isolated from chassis
  • Aircraft power system (DC): +ve wire, GND ->Carries current, Although chassis can be connected to DC GND, it is not intended to carry current.
  • Automotive power system (AC): Line, neutral-> Carries current, Neutral isolated from chassis
  • Automotive power system (DC): +ve wire, chassis-> Carries current
  • – Dynamic_equilibrium Nov 09 '23 at 06:07
  • Sorry for the above cluttered comment -> not able to format. But is my understanding correct? – Dynamic_equilibrium Nov 09 '23 at 06:09
    @DivyaK.S Some other thoughts: (1) aircraft are continually undergoing refinements and improvements in structural exotics and the electrical resistance of these is too great to be used for a return path. (2) accidental contact of some line to the structure won't cause a fault. (3) the two conductors can now be run together and even twisted to reduce EMI. (4) electrolytic action between various materials when exposed to high currents is reduced/eliminated. (5) And better circuit connections, and reduced variation in same, also results. – periblepsis Nov 09 '23 at 09:51
  • @Divya K.S yes you understand correctly. – Frog Nov 09 '23 at 21:14
  • @periblepsis electrolytic effects are not to be underestimated, I’ve heard rumours of an aviator drawing in pencil around a suspect rivet and then returning a little while later to find that the pencil line had corroded all the way through the plane’s skin – Frog Nov 09 '23 at 21:17
