In my quest on how to select the relevant TVS diode, I came across this document.
Page 3 paragraph 2.1, it is stated :
Vrwm
The reverse working maximum voltage (VRWM) is defined as the voltage that can be applied to a TVS diode with an assurance that the diode will not, over process or temperature, conduct significant current. The definition of ‘significant current’ depends on the TVS manufacturer, but generally it is < 100 nA. The VRWM specification enables a designer to select a device that will see minimal leakage across all operating conditions. In a design, VRWM should be selected to ensure that it is above the expected maximum operating voltage. If the applied voltage rises above VRWM, there is a chance to see diode leakage increase significantly. For example, if the protected line operates at 5 V nominal with a maximum variance up to 7 V, ensure that the VRWM is 7 V or greater.
I don't understand why the last sentence is exact:
If nominal operation of device is 5 V, with maximum 7 V. I understand that if the voltage raises above 7 V, the device will die. So, If I choose a TVS with a Vrmw of 8 V (as noted in the last sentence "ensure that the VRWM is 7 V or greater") and the voltage goes to 7.5 V, my interpretation is that the diode will not conduct significantly (because voltage is below Vrmw) and my device will die.
What's wrong with my understanding?
