As discussed here, I'm trying to use a MOSFET for reverse polarity protection.
I got an IRFB7440PbF, which has a low Rds(On) (2mOhm,) suitable Vgs (I'm using a 5V power supply,) and what I thought would be a proper voltage drop.
I've tested it by simply connecting it between a 5V power supply and a Raspberry Pi (which would use less than 3A.) The Pi complained about low voltage. I measured 4.6V.
When reading the chart, I'm getting that the voltage drop should be 0.1V, so I should get around 4.9V:
Drain to source volage depending on drain to source current
What have I gotten wrong? Would you know any part that would meet my requirements? (5V @ 6A, dropping at most 0.2V)
JRE
  • 71,321
  • 107
  • 188
user1532080
  • 177
The IRFB7440PbF (unlike the MOSFET in your previous question) is an N channel device so it's unlikely you are able to use it for what you need: -
The volt drop you see is probably the forward volt drop of the parasitic bulk diode inside the N channel MOSFET and not the actual MOSFET itself.
Andy aka
  • 456,226
  • 28
  • 367
  • 807
