20
This question will most likely come down to semantics. A friend and I were discussing a point that his EE instructor made, that if you consider the output from a solar panel over more than a few days, it effectively is a cyclic wave, and thus is AC at that time scale. I disagreed with that point and said that it is still DC, albeit with variable output.
Now, while I agree that it's useful to consider the longer measurement period and explain to students how one might conclude it is an 11.6 µHz signal with a DC offset or something, I feel it is misleading to label it AC.
The output voltage is always positive or zero -- unless you measure that signal with reference to some arbitrary point other than one of the panel's terminals. In order to get a negative voltage one would have to measure with reference to a midpoint (e.g. between two serially-connected panels).
I liken the sub-1-Hz "signal" example to an analogy, and maintain that it is somewhat useful, but only as much as, say, water analogies are to explaining electrical phenomenon.
In any case, if I measure a signal where no polarity reversal occurs (at any time scale), should it be considered AC? If so, is "alternating" merely describing the change in amplitude/voltage? Again, if so, does that make current reversal due to polarity reversal a non-requirement to be considered AC?
(A related question asks if a square wave still considered DC. Perhaps a short version of my question is: "Is a square or sine wave with no zero crossing still considered AC?")
JYelton
  • 34,119
  • 33
  • 145
  • 265
    the output from a solar panel over more than a few days, it effectively is a cyclic wave, and thus is AC at that time scale. I would say that it is neither AC nor DC but actually both. In my definition, DC is the average current over all days. This DC current is constant over the considered time period. Then on top of that there are variations which is the AC part. – Bimpelrekkie Jun 21 '21 at 19:49
    @Bimpelrekkie Ah the old AC/DC duality function, sister to that of wave/particle duality. :) – JYelton Jun 21 '21 at 19:50
    IMO, it's "AC with a DC bias". You can't really justify NOT calling it "AC" because (unlike DC), it will pass signals through a capacitor. Only AC can do that. – Kyle B Jun 21 '21 at 20:48
    Well using that analogy, the voltage of a phone battery is also AC, as i fluctuates up and down over the course of a couple of days... – Linkyyy Jun 21 '21 at 20:51
    A capacitor passes DC current during the response to transient conditions. It is only by custom and convention that we say the capacitor passes AC current and blocks DC current. Technically the capacitor takes DC charge until its potential reaches the potential imposed by the surroundings and then it stops taking any more DC current. – SystemTheory Jun 21 '21 at 21:39
    Since there is no absolute definition for this, would all answers be opinion-based? – Justme Jun 21 '21 at 23:05
    @Kyle but every signal or potential or current can be said to be AC with a DC bias.... – Stian Jun 22 '21 at 04:50
    @StianYttervik Pretty much yes, or it wouldn't be a "signal". It'd be a DC power supply ;) – Kyle B Jun 22 '21 at 05:30
    I'll add... When we do the 'short caps and open inductor' to do what everybody agrees is an "AC analysis" in a circuit, it doesn't matter if the signal itself ever actually goes negative. So if we ALL call that AC analysis, how can ANYBODY make a case that's actually DC???? – Kyle B Jun 22 '21 at 05:32
    @Linkyyy perhaps we should consider the magnitude of the 2 components. My camping solar panel is 12V nominal, and presumably 0V in the middle of the night, so 12Vac@11.6µHz+6Vdc. At the right angle is could be close to sinusoidal. My phone battery will be more like 4.2V full and 3.2V if I run it right down over the course of a day, so 1Vac (same 11.6µHz)+3.7Vdc. That will also be an asymmetric sawtooth with a flat top, if we assume usage is even through the day and it gets charged overnight, filling up well before morning /‾/‾. Any top-up charging will further break the periodicity – Chris H Jun 22 '21 at 08:34
    I've always felt that calling anything "AC" or "DC" without qualifications is a bit misleading unless it's purely AC or purely DC; everything else has both an AC component and a DC component. It's like asking whether 1+j is a real number or an imaginary number; it's neither, it's a complex number. – Hearth Jun 22 '21 at 13:05
    Theoretically, a pure DC signal has an infinite-time support (domain) and so does a pure sine wave (which I assume is what is meant by an AC signal). So either way, neither really exist, as all causal signals exist starting at some time-point (and our observations of them will end at some point in time). Also, as pointed out above, some inconsistencies will exist in real-world signals, e.g. for electrical signals there are stray capacitances and unwanted resistance present, affecting the signals as well as the equipment. – JosephDoggie Jun 22 '21 at 16:07
  • Here's a recent one on this: https://electronics.stackexchange.com/q/553412/110857 – ilkkachu Jun 22 '21 at 16:50
  • Was it designed to be AC but has a large DC offset? Call it AC. Was it designed to be DC but has a large AC ripple? Call is DC, even if it has zero crossings. – Thomas Weller Jun 23 '21 at 08:07
  • "The output voltage is always positive or zero" --> It a question about current (AC: alternating current), not voltage. If the current sign alternates, sounds like AC to me. – chux - Reinstate Monica Jun 23 '21 at 23:02
  • Is a zebra black with white stripes or white with black stripes? That is to say, calling something AC or DC is only to give people an idea of how it will behave with certain components like capacitors. Beyond that, the platonic meaning of the terms are pointless. So it is 100%, as you say, semantics. – Joel Keene Jun 24 '21 at 01:05
9 Answers9
57
This has been discussed (argued) several times on this site and the result is always both yes and no. My own take is:
  1. If the polarity never actually reverses then it's not AC.
  2. At the same time we can represent it as AC with a large DC offset.
  3. Alternately we can represent it as DC with an AC ripple waveform superimposed.
I wouldn't bother getting into an argument about it - commenters please note. Take whichever view best suits the analysis you are doing or that seems most intuitive for a particular situation.
Transistor
  • 175,532
  • 13
  • 190
  • 404
    Thanks for the perspective. My main goal was to point out that context is everything. Given the context of "solar power from panels" I felt it was prudent to point out that it's DC. I did search for previous coverage of this question; if you know of any particularly good posts, I'd appreciate links. – JYelton Jun 21 '21 at 19:51
    Technically item 1 is correct when applying a statistical model for the net motion of charge carriers in a conductor or semiconductor medium. However item 2 is not incorrect because by convention it is common to refer to the transient or time-varying components as alternating current even when the net motion of charge carriers would remain in the same direction with a time-varying component (AC with large DC offset). – SystemTheory Jun 21 '21 at 21:06
    I'm not going to argue. He-he-he! – Transistor Jun 21 '21 at 21:08
  • So you could change a non AC signal to an AC signal by just DC-shifting the potential?
  • – lalala Jun 22 '21 at 19:40
    @lalala, sure. A DC decoupling (blocking) capacitor in an audio amplifier does that. – Transistor Jun 22 '21 at 19:59
  • Every periodic signal can be decomposed in two orthogonal components, an AC and a DC component. The L2-norm of these two components is the RMS value. Based on this fact, I would agree with your points 2 or 3, but not with 1: Any time varying signal, even without zero crossings, has an AC component. – Bart Jun 29 '21 at 14:00
  • In the case of, say, DC solar panels, we're not talking about a signal but about energy transfer. In that case, it is better to regard it as time-varying DC, as the net transfer is what you care about and typically you integrate over the time-varying component anyway. Like @Transistor says, it depends what's useful in a given circumstance. – Dan Apr 11 '23 at 18:31
