I've got a 2009 Harley-Davidson XR1200 (that can be seen at the bottom of my bio in my profile).
I've replaced the stock incandescent bulbs with nice looking LEDs; however, the stock bulbs were 2-way and had 3 wires (one for ground and one to each filament).
The new LEDs are simply ON/OFF and have 2 wires. Since LEDs do not draw as much power as the stock filament bulbs, load resistors (that come with the LEDs) are included. These resistors get very hot because they pass a lot of current so the electronics on the motorcycle will not think there is a burnt bulb.
I got to thinking that I could wire a Normally Closed relay just past the Turn Signal Module (TSM) so that the LEDs were ON until the TSM sent the "ON" signal - which would cause the LEDs to blink OFF.
The more I thought about how simple this would be to do, the more I thought that this has to have been done by someone before, so I did some research and found several posts where people have done this.
Different posts use different resistors, then I started discovering where some people were clever enough to place a diode and a resistor in parallel so that the LEDs would dim or get brighter with the blink signals, making them appear to be a 3 wire setup.
So far, the best "How To" I've found is a thread called Converting 2-wire to 3 wire Signals on the R6 Forum. This post talks about using electrical components from Radio Shack, but there is not one very close to me. It would be easier for me to buy the components online, if I knew what to ask for.
So, how would I go about getting diodes and resistors that are the right ratings for my application?
I've found a nice Blue Ox 6 Amp diode pack that is sealed to keep out moisture, which would be very nice on a motorcycle, but I don't know if 6 Amps is over kill or about right. eBay has 17,000+ diodes under $3, but I don't know how to pick what I need.
Would the resistor in this diode/resistor setup get as hot as the load resistor in the setup I have now?
EDIT:
To answer the comments: The LEDs I have now only turn on when the turn signals are activated.
Q) What type of LEDs are you using?
A) Rizoma "Zero-11" (link)
Their website shows 12V - 13W on this drawing:
