-1
I asked a similar question here a few days ago.
I'm asking this question here again because the answers were ambiguous.
Consider the first picture, no collector battery, only a base voltage is given. In this case the base-emitter junction would simply act as a normal diode, and hence the current \$i\$ would enter the emitter and leave through base, hence emitter and base current would be the same.
Next, let us add a battery to the collector as shown in the second picture. Now what would happen? I'm considering the following scenarios:
  1. The same current \$i\$ (no additional emitter current due to the collector battery) would distribute to the collector in the ratio of beta. (Quite simple to imagine.)
  2. After adding the battery a new current of amount \$L\$ would be pulled from the emitter so now the total emitter current is \$i+L\$. This new \$i+L\$ would be distributed in the ratio of beta to the collector.
Which one is correct? Is there any other possible scenario which I'm missing?
JRE
  • 71,321
  • 107
  • 188
Sayan
  • 739
  • 18
  • Please give a link to the previous question you're referring to. 2. When you ask "which one is correct" what set of possibilities are you asking about?
  • – The Photon Dec 27 '20 at 18:12
    It depends on how much current the sources can supply, but it will probably fry your BJT. – Hearth Dec 27 '20 at 18:12
  • @ the Photon... that question not however exactly the same, but they fundamentally linked, here is the link : https://electronics.stackexchange.com/questions/538383/emitter-current/538544#538544, and the set possibilities i can imagine right now is already written in my post, kindly see. – Sayan Dec 27 '20 at 18:17
  • @ hearth please elaborate – Sayan Dec 27 '20 at 18:18
    @Sayan In the future, don't put a space after the @ if you want us to get notified, I just saw this by chance. To elaborate, you should never hook up a BJT to a voltage source without some kind of current limiting element (usually a resistor) in series with the base-emitter junction, else you're going to fry it, and then there won't be any current going through it at all and it might be on fire. – Hearth Dec 27 '20 at 18:36
  • @Hearth alright, assume the circuit is properly designed with the current limiting resistors, then what would happen out of these possibilities? I'm not interested here about the practical issue, i.e excess current, rather I want to understand the current distribution . – Sayan Dec 27 '20 at 18:41
  • @Sayan Now it depends on how the resistors are configured, though. – Hearth Dec 27 '20 at 18:43
  • @Hearth let's say the circuit is configured with emitter resistor, no collector resistor. – Sayan Dec 27 '20 at 18:45
    @Sayan I went into more detail in my answer below. – Hearth Dec 27 '20 at 18:54
    @Sayan The question posed here is fundamentally different from the one posed previously. Here, you are supplying a fixed voltage between the base and emitter. In the previous question, there is a fixed voltage across the base-emitter junction AND a resistor. Big, big difference. – Math Keeps Me Busy Dec 27 '20 at 19:26
  • I think you are confused. Given the battery polarity, and assuming this is an NPN transistor, current would enter the base and leave through the emitter. If it is a PNP transistor, then the base emitter junction is under reverse bias and only a small leakage current would flow. – user57037 Dec 27 '20 at 21:57
  • @mkeith everytime i consider electron current. – Sayan Dec 28 '20 at 07:59
    @Sayan well, don't do that. Nobody else does it that way. It only creates confusion. – user57037 Dec 28 '20 at 10:13
