I'm trying to figure out what this 5-pin IC from the below image could be:
The SMD Package looks to be TSSOP5.
The component is used in the Kemet SS-430 sensor module. I think, is part of the output amplification circuit for the Kemet PL-N823-01 sensor. My guess is that the IC is some kind of opamp or comparator.
(rectangles = unmarked SMD parts. They are mostly resistors and capacitors, I think.)
Could you help me identify this component with the ">10" marking?
Thanks!
PS: I would like to use the PL-N823-01 in a project, but unfortunately I did not found a reference design for it yet. So, I'm trying to figure the things out from the SS-430 module.
However, I took a look with an oscilloscope and the output of the sensor varies at about 650-850mV. That gets into the opamp IC and gets amplified to the range of 800mV-3V. This signal then is fed directly into a PIC12F617 micro-controller, probably into and ADC or comparator.
– bluetiger9 Jan 01 '20 at 17:17
