First for all. Am not an electrical enginner, am just an amateur artisan, pretending make intetesting gadgets.
So the situation is this. I need to make a circuit in a sheet of paper for just turn on and turn off a very very little led light. The challenge: make this as thin as possible. Ideally with 0.5mm of thickness.
What I already made: I found a very interesting example in this link https://www.electroschematics.com/5996/touch-switch-circuits/
But the problem is, again, the thickness, only the ic 555 has a 3.5 mm, for me its to much. In summary, is there another way to do this circuit but in a very very thin way?.
Edu gomez
If all you need is a very weak light, use a neon lamp and a safe, low current power supply. Bridging two conductive ink traces between the lamp and supply with a finger would light the lamp. Using audio-frequency or low frequency RF would make the circuit easier to turn on, since it would bypass skin resistance with capacitive coupling.
DrMoishe Pippik
  • 4,067
  • 13
0.5mm rules out most packaged ICs (that’s about the thickness of a sawn wafer.) If you could use chip-on-board it’s possible, or something in chip-scale packaging you might be able to make that.
That said, a Silego GPAK device gets pretty close, at about 0.75mm.
You didn’t mention your battery - how are you dealing with that?
More: have a look here. Some candidates that meet your criteria possibly. What are the smallest microcontrollers?
hacktastical
  • 53,912
  • 49
  • 152
