I find analog switch usually label the two terminal of the switch channel as "S"(Source) and "D"(Drain). Such as this. I think they are equal in function, either can be used as input or output. So why still use the terminology from MOSFETs?
diverger
  • 5,848
  • 45
  • 83
  • They are not fully equal. See https://electronics.stackexchange.com/a/308885/34873 – Joren Vaes Sep 13 '17 at 11:18
    @JorenVaes Yes they are in ICs. Furthermore the bulk is not connected to the source, but to the "lowest potential" in nMOSFET (which might not correspont to the source. Think about the pull-down network of a NAND gate) and "highest potential" for pMOSFET. The source and drain are not fixed: in an nMOSFET the source is the one with the lowest potential, the drain is that one with the highest (opposite on pMOSFETs). – next-hack Sep 13 '17 at 14:25
  • @next-hack I said this as a simplification for the OP. As I discuss in my post, reality is much more copmlicated. – Joren Vaes Sep 13 '17 at 14:33
First line of description says:
The ADG1436 is a monolithic CMOS device containing two independently selectable SPDT switches
Also, it is worth to see inside.
smajli
  • 896
  • 13
  • Yes, I know, they are different in internal. The D is connected to body in NMOS, and S connected to body in PMOS. But when use them, there are any difference? Can't we just use them as a normal switch? – diverger Sep 13 '17 at 11:57
  • @diverger The drain is not connected to body! In ICs the body of nMOSFETs is connected to gnd (or Vss), and for pMOSFETs it is connected to Vdd. The pins "S" and "D" in the IC are symmetrical. There is no sense calling them drain or source (some datasheets use S/D_1 and S/D_2). In fact, in an integrated planar nMOSFET, the drain is the terminal connected to the n+ region that has the highest potential. The source is the terminal connected to the n+ region that has the lowest potential (opposite occurs for pMOSFETs). In an t-gate, therefore, S and D function are not assigned a-priori. – next-hack Sep 13 '17 at 14:40
  • I know the situation in discrete MOSFET. But I may don't understand your figure well. What's the meaning of "BODY" in the figure? It means the V-(+) terminal is the body? – diverger Sep 13 '17 at 15:31
Different datasheets might have different conventions. Let's consider the famous 4066, which are bilateral switches (Transmission gates).
Here they call each terminal In/Out:
https://www.intersil.com/content/dam/Intersil/documents/cd40/cd4066bms.pdf
Here they call In OR out:
http://www.ti.com/lit/ds/symlink/cd4066b.pdf
Here x and y:
http://www.onsemi.com/pub/Collateral/MC74LVXT4066-D.PDF
next-hack
  • 5,357
  • 15
  • 34
  • Thanks for your links. I only used analog switches from ADI, so it's maybe ADI's conventions to label them as "S" and "D". – diverger Sep 13 '17 at 15:19
