I have a Fairchild LM78M05CT (datasheet) as a 5V regulator for a µC circuit that also has an ICSP port.
The actual circuit is the one in this question: Review of my first ever PCB design for a watering control robot.
I've seen some versions of the 7805 regulator data sheets where the application notes recommend a diode from Vout to Vin in order to protect the device from burning out if the output voltage goes higher than the input. However the datasheet to the Fairchild LM78M05CT doesn't show such a diode in the application notes. Hence I assumed it wasn't necessary with their implementation.
I went to program my device through the ICSP port so I disconnected it from the DC power (Vin to regulator unconnected) and applied +5V and GND to the ICSP header to power the target µC (which drove +5V to Vout of the regulator).
The programming failed, and the target device has a "electronic" smell not present before. Also a LED on the Vin side of the regulator shines indicating a current from Vout to Vin. When I next plugged in the DC cord I got a spark from the ground terminal (and there is a black residue from it on the solder mask) of the DC plug and immediately unplugged the DC cord.
Further I measure (in situ) only 500R or so between the Vout and GND pins on the regulator both ways which is much less than what I would have expected.
So my questions are:
  1. Is my regulator shot?
  2. Did I actually need the diode from Vout to Vin (would that have protected my device) in order to be able to program with ICSP?
  3. Should I have had the DC power connected to the target? I would have to have had 5V and GND between the target and programmer (arduino working as ISP) to ensure matching signal levels so I would have had two +5V drivers.
  4. Any other measurements I should make?
Status Update: Appears that I also bricked the DC adapter, LED doesn't come on and no voltage on terminals. Desoldered the regulator, all pin combinations with polarity measure within tolerance of a new one and it doesn't smell. Applied 5V over ICSP again with DC plug removed and no regulator mounted, smell came back and power LED lit up indicating RL1 is providing 5V on pin 11 in the circuit linked up top. Also the relay smells funny.
Emily L.
  • 273
  • I would have run the device from its normal PSU, and connected the ICSP's ground (but not 5V). At this stage I think my move would be to replace the 7805, check any diodes for short circuits, power the board from a current-limited PSU and try again (measuring the current draw and all supply voltages first!) –  Jul 09 '17 at 17:29
  • A 7805 should be zero capacitor stable, pull it out and see what it does with a bench power supply – sstobbe Jul 09 '17 at 23:44
It seems rather unlikely to me that this is the cause. The output voltage has to be greater than the reverse breakdown of the B-E junctions in the regulator to cause damage, and 5V is not. There also has to be significant current flowing back (both conditions are necessary for damage to occur).
For example, the TI datasheet specifically says:
I suggest proceeding with caution and looking for something else that may have caused what appears to be significant damage. For example, reversed power connections.
Spehro Pefhany
  • 397,265
  • 22
  • 337
  • 893
    Is it possible the Fairchild LM7805 has a different realisation as the linked data sheet mentions no such shunt diode nor any break down voltages? Also they mention short circuit protection. – Emily L. Jul 09 '17 at 23:33
    @EmilyL. Unlikely. They're all pretty similar.. all have short-circuit protection and shut down with very high junction temperature. But those protections can't save the chip if it's abused by putting 10V on the output with input grounded (or 50V on the input). – Spehro Pefhany Jul 09 '17 at 23:37
    P.S., the kind of symptoms you describe can sometimes be caused by a sneak ground. For example, your ICSP setup has a ground to earth through the computer if it's a desktop or many notebook computers. That can cause issues if your circuit also has a ground to earth somewhere, and very serious issues if the two are not nominally at the same potential. – Spehro Pefhany Jul 09 '17 at 23:42
  • That's one reason why I didn't want to have the DC plug connected while powering from ICSP that is powered by USB from my mains connected PC. – Emily L. Jul 10 '17 at 07:52
Bad news - You probably need the diode. The 7805 has an emitter follower on the output stage, so you have probably let the smoke out. I have blown this specific part with the charge from large output decoupling capacitors when the input was shorted. I'm not sure how you damaged your target.
For ICSP, you can add the diode but realize your programmer will have to power whatever is on the back side, or you can select the target's vdd on some programmers. However, I usually put a blocking Schottky diode in series with the output.
John Birckhead
  • 10,994
  • 28
  • A Schottky from Vout ? I'll have to see how (if) that affects the rest of my circuit. For now I think I'll jurryrig a shunt diode on the pins as the board is already made. – Emily L. Jul 09 '17 at 23:25
