If I connect this very small load (3 LEDs) to a mains to USB adapter, it's fine. Full brightness, great.
I can't even measure the current it's so low.
However, if I connect it to my PC it does 3 things:
It flashes a bit from bright to dim, stays dim and windows says it's malfunctioning.
Nothing has shorted out or anything like that, so is there a minimum current I should be drawing from a PC's USB port?
Marcus Müller
  • 94,373
  • 139
  • 252
  • I think you've measured, or connected something wrong, can you give more details of the setup and how you made the measurement – Jasen Слава Україні Dec 19 '16 at 21:23
  • It was measured correctly, just using one of the little USB testers that are so common nowadays. – DespairingSquid Dec 19 '16 at 21:27
    How are the LEDs connected (series/parallel)? What is their forward voltage? Is there really no series resistor? – dim Dec 19 '16 at 21:40
  • most LEDs have a forward current somewhere between 5mA and 20mA – even the cheapest multimeters I've ever seen can measure that. You will have to add a drawing of your system, or else it remains unclear!
  • – Marcus Müller Dec 19 '16 at 21:43
  • It's possible the PC is complaining because it can't work out what's plugged in and is cutting the power (I have an intel atom board that does something similar - it can be a real pain sometimes) – Sam Dec 19 '16 at 21:57
    it could be that the measuring device is inaccurate, I have one that matches that description, and with it any current under 50mA reads as 0 – Jasen Слава Україні Dec 20 '16 at 00:44
