Sorry for the amount of code in advance (I added the code since I was unsure whether it is needed here to resolve my issue).
My main goal is to link two components which are in two separate .vhd files together in a block in a third file.
Lets say that I have got the following code in my file chooser.vhd:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library work;
use work.all;
entity chooser is
    port(
        clk, rst : in std_logic;
        DATA : in std_logic_vector(4 downto 0);
        A : out std_logic_vector(4 downto 0);
        Src : in std_logic_vector(1 downto 0);
        SOp : in std_logic_vector(1 downto 0);
        debug : out std_logic_vector(4 downto 0)
end entity;
architecture structural of chooser is
-- here
begin
end architecture;
And that I have two components in another two files called registry.vhd and MUX3x5.vhd
MUX3x5.vhd
library ieee;
entity MUX3x5 is
    port(
        IN0 : in std_logic_vector(4 downto 0);
        IN1 : in std_logic_vector(4 downto 0);
        IN2 : in std_logic_vector(4 downto 0);
        SEL : in std_logic_vector(1 downto 0);
        O : out std_logic_vector(4 downto 0)
end entity;
architecture behaviour of MUX3x5 is
end architecture;
registry.vhd has an output of 5 bits
I want to connect them like follows inside chooser.vhd registry --> MUX3x5 (on the second input). How do I do that in my chooser architecture above?
Should I declare them as components with their ports as seen in the entity declaration in the original files for the components in the architecture and then route them in the port map? Like so:
Attempt
signal -- signals here
-- copy of the inputs/outputs in the entity declaration in the file above
component MUX3x5 is
    port(
end component;
component registry is
    port(
         -- some signals here
         TS : out std_logic_vector(4 downto 0)
begin
-- port map here
    port map(
            TS => IN1;
            -- other maps
end architecture;
Clone
  • 275
    That's it. Except that it misses the component used in the port mapping : registry0 : registry port map ( ...);. – A. Kieffer Dec 06 '16 at 16:16
  • @A.Kieffer, thank you for your input. Where should that line go? Should it be instead of the normal port map( part in the chooser architecture? – Clone Dec 06 '16 at 16:32
You already have the solution. Just add the name of the entity as A.Kieffer said in his comment and make sure that the maps are separated by a , and not ;
signal mux_IN0 : std_logic_vector(4 downto 0);
signal mux_IN1 : std_logic_vector(4 downto 0);
signal mux_IN2 : std_logic_vector(4 downto 0);
signal mux_SEL : std_logic_vector(1 downto 0);
signal mux_O   : std_logic_vector(4 downto 0);
component MUX3x5 is
    port(
end component;
    port(
begin
some_name: registry
    port map(
            TS => mux_in1,    -- use , and not ;
            -- other maps
mux: MUX3x5
port map(
    IN0 => mux_in0,
    IN1 => mux_in1,
    IN2 => mux_in2,
    SEL => mux_sel,
    O   => mux_o
end architecture;
Botnic
  • 2,275
  • 20
  • 33
  • Thank you for your input! If I were to connect MUX3x5 to registry should I then put some_name: MUX3x5 port map( O => -- some input port); instead? – Clone Dec 06 '16 at 16:50
  • I updated the code – Botnic Dec 06 '16 at 18:31
  • Hi @Botnic, do we need a end component; for component regisrty? Also, I've seen VHDL codes without initializing components. They just use some_name : entity work.vhdl_entity_in_otherfile Is this a new feature from what you described above? – vpp Oct 31 '22 at 14:13
