I have been using a Spartan 6 where the TX/RX pins are multiplexed with the IO pins, I can't find any dedicated TX/RX pins on the Xilinx Zynq Soc, is it a Xilinx thing to multiplex TX/RX with IO pins? I not able to find any thing in the data sheet.
EDIT:
Its using the Arm Cortex A9 processor, I presume the TX/RX pins would be the same as on the a9? would I be correct in thinking so?
Alex
  • 552
  • 15
I am assuming you are referring to the TX/RX signals of a UART.
You'll find plenty of information in the SoC Technical Manual, specially in chapter 19. The UART signals can be assigned to different pins which you can see in the table 19-4: UART MIO Pins and EMIO Signal, page 604, or otherwise in the MIO-at-a-Glance Table in page 53.
Ironil
  • 73
