I have a voltage divider, and the output goes to OP amp.
This is from my schoolwork.
-1 to +1 input | [R1] 1000 ohms | ---> output to op amp | [R2] 1000 ohms | 2v
How do I calculate output that goes to op amp? Regular voltage divider formula is Vout=Vin×(R2÷(R1+R2)) But lets say V1 is -1 and other end is 2v, what do i take for Vin? 3 volts?
Edit: Found the whole exercise enter image description here
V1 is 4v V2 is from -1v to 1v And where the ground symbol is, there should be 2v. What do I take for V2 in formula whem V2 is -1 or +1?
Murel
  • 13
  • Could you add a schematic? Your ASCII art is a bit difficult to understand. There's a button up on top of the editor pane that allows you to add a schematic. – uint128_t Jan 24 '16 at 17:14
  • It would be more clear what you're asking if you included a schematic. But I think what you are looking for is $V_o=V_- + (V_+-V_-)\frac{R_2}{R_1+R_2}$ which is the formula for the output from a voltage divider connected between voltages $V_-$ and $V_+$. – The Photon Jan 24 '16 at 17:16
  • There is no R2 in your schematic, so it's not clear what's the connection from the schematic to your formulas. – The Photon Jan 24 '16 at 18:42
But I think what you are looking for is \$V_o=V_- + (V_+-V_-)\frac{R_2}{R_1+R_2}\$ which is the formula for the output from a voltage divider connected between voltages \$V_-\$ and \$V_+\$.
You can derive this formula yourself using the principle of superposition.
The Photon
  • 129,671
  • 164
  • 309
