I have to do a instantation of several components
I suppose the code for this instantation would be something like this:
componentA: componentB port map(
output_ca => input_cb
componentA: componentC port map(
output_ca => input_cc
But I know that part of the code before is wrong, because 'ouput_ca' has 6 bits and input_cb, and input_cc has only 3 bits every one of them. How would be written this code in a good way? Thank you so much for your help.
Peterstone
  • 945
  • 15
  • 30
You must use some signals, you can't map straight from one pin to another (I'm also using direct instantiation to avoid creating component declarations - see also my answer here):
signal aout : std_logic_vector(5 downto 0);
A: entity work.componentA port map(
    output_pin => aout
B: entity work.componentB port map(
    input_pin => aout(5 downto 3)
C: entity work.componentC port map(
    input_pin => aout(2 downto 0)
Aside
You seem to be confused in your instantiation syntax. You wrote:
componentA:componentB port map (...
implying that componentA connects to component B.
What is actually being said is
individual_name_of_component: name_of_entity
So you pick an entity which you are instantiating on the right of the : and give it a name on the left.
Martin Thompson
  • 8,499
  • 23
  • 44
  • Cool, I didn't know about direct instantiation. I always hated keeping component declarations in sync. – ajs410 Jul 12 '11 at 18:09
