30
I would like to make a board which can be plugged directly into the USB port of a computer, instead of using a separate male "USB-A" connector. I have seen this system used for very small USB memory keys, such as this one. How would I lay out a PCB with such a "connector" built in?
I am using Eagle. Does anyone have a library for it? Can anyone suggest another way to do this?
drxzcl
  • 3,775
  • 31
  • 32
The Sparkfun Eagle Library (pre-6.0, 6.0+) has one. It's called "USBPCB".
Here's a project using it.
Toby Jaffey
  • 28,836
  • 19
  • 98
  • 150
  • You are right! It was staring me right in the face. Thanks bunches, the eagle library system can be annoying at times. – drxzcl Apr 17 '11 at 20:13
    BTW, do you have any idea what the proper PCB thickness would be? It looks like it's at least 1mm, maybe more. – drxzcl Apr 18 '11 at 22:41
  • I'm not sure, I'd suggest contacting the author of the GoodFET project I posted – Toby Jaffey Apr 19 '11 at 07:54
    Btw I emailed Travis of GoodFET fame. He said that the GF31 is produced on a board with a thickness of 0.078". He also suggested to round up when performing metric conversion to 2mm. – drxzcl Apr 20 '11 at 20:56
    @drxzc - For prototypes, I would err on the side of thinner PCB, and if needed, simply add some tape on the back-side to make it thicker. That way, you're going to get something that will work. – Connor Wolf Oct 29 '12 at 03:06
    @drxzcl 1.6mm is what you generally get if you don't specifically ask for something else. – Chintalagiri Shashank May 13 '13 at 13:18
For reference: I tried the SparkFun footprint one on a 2mm thick board, the result was unsatisfying: the connectors on PCB oxidized and the connection was faulty, I didn't get the problem right away, but such bizarre things as the computer recognizing my FT230X chip (Serial adapter) as a Microsoft Ballpoint Mouse and the computer mouse begun to jump everywhere and click randomly (very annoying). Once I scraped the metal it worked very well again, so no deal, get a proper connector.
Solenoid
  • 181
  • 13
    It would work fine if you had the PCB properly gold-plated. I don't think anyone would think that the tinned board surface is really reliable over any sort of timeframe. – Connor Wolf May 13 '13 at 09:41
  • @Connor Wolf: absolutely, but PCB houses do not offer such services and one can much less do it at home, but it's how connectors should be made. This was a noob experiment since I haven't found anything beyond theory on the net, I sacrificed some of my time to confirm it. It's usable, but be careful. – Solenoid May 13 '13 at 14:05
    What bizarre PCB house are you using? Pretty much every PCB house I have ever looked at offer gold-plating. It's not free, but I bet even the PCB house you use can gold-plate your board. Ask them! – Connor Wolf May 14 '13 at 03:53
    @Connor Wolf: Then I learned something new today, I'm completely self taught when it comes to PCB making so information isn't easy to come by. – Solenoid May 16 '13 at 12:37
    Most board-houses (any decent one, anyways) will have a big list of all the stuff they can do. Read it! Or better yet, read the documentation from several different board houses, and compare and contrast it. You can infer a lot about the ease and mechanics of making boards that way. – Connor Wolf May 17 '13 at 02:39
    Not only it's easy to do gold plating at home (you buy off-the-shelf chemical kits for it), but many PCB houses do in fact offer it even for small quantities. – Kuba hasn't forgotten Monica Jan 03 '14 at 17:38
    OSHPark do gold plating for free. You only get one thickness though (1.6 mm) which doesn't seem to be enough. Perhaps a small piece of shim metal could be soldered to the opposite side to make it thicker? – Timmmm Jun 16 '14 at 13:37
    "such bizarre things as the computer recognizing my FT230X chip (Serial adapter) as a Microsoft Ballpoint Mouse and the computer mouse begun to jump everywhere and click randomly (very annoying)" are a software problem, and provide absolutely zero evidence of any circuit misbehavior. Simply go into the serial port properties in Device Manager and disable "Serial Enumeration". On newer chip/driver combinations (including yours) you can set a bit using FT_Prog such that the driver won't install serenum.sys in the first place, thus saving you the step of turning it off. – Ben Voigt Jan 14 '16 at 16:01
    It should be noted that even commercial caseless usb plugs tend to be very iffy when it comes to working properly if plugged in and out a lot. gold plated or not. – Lassi Kinnunen Jan 03 '20 at 15:06
