With Ubuntu 17.10, Okular (installed through the Ubuntu repositories, i. e. apt install okular) seems to work a lot worse than in previous versions. This is both on Wayland and on the X session. Here is a screenshot:
For example: As you can see, only the item “Contents” in the left sidebar has an icon. The other ones (“Thumbnails”, “Reviews”, “Bookmarks”) should have icons as well (see e. g. this screenshot).
Moreover, when I open Okular from the Terminal, I get a bunch of output:
inotify_add_watch("/home/user/.config/ibus/bus/9f77c45ee0ec4b6a89aaaa7669ff56c1-unix-0") failed: "No space left on device" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/16/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/22/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/24/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/32/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/48/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/64/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/128/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/16/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/22/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/24/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/32/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/48/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/64/" Invalid Context= "stock" line for icon theme: "/usr/share/icons/ubuntu-mono-dark/stock/128/"
The messages about the icon theme might be related to the missing icons. The first line apparently means that the limit of inotify watches has been reached – why is that happening?
Lastly, the UI theme looks nothing like other applications in Ubuntu (I guess this is a problem with Qt applications in general?) – look at the scroll bars, for example. I suppose this has to do with the move back to GNOME? It used to be much better in Ubuntu versions before 17.10.
Is there any way to fix/work around these issues?
As another data point, there is the question “Okular instances do not group under single icon in desktop dock on Ubuntu 17.10”, but that already has a solution in the link.
