As you know , Ubuntu 17.04 has come to end of life. I'm hesitating to upgrade to 17.10. Is it worth it ? I can not afford re installing the Os nor the loss of very sensitive data. Will be any problem with my current 17.04 dektops programs? Thank you.
Asked
Active
Viewed 1,445 times
If you are not connected to the web; 17.04 is good.
Ubuntu 17.04 has not been patched for Meltdown, Spectre & any patches after 13-Jan-2018 which is not a problem if your machine is not connected to the web, but to protect your data if connected to the web upgrading will provide better security.
The decision is yours, but
- If that data is important to you - backup!
- If the data is sensitive and machine is connected to the web - stay updated & backup.
- If you don't like upgrading - use LTS versions....
however if you're not connected to the web, 17.04 is all good
guiverc
- 33,561
I agree with guiverc good advice about LTS versions. I went from 14.04 to 16.04 and have 18.04 on my to-do list next year.
There is another option to consider if you are on 17.04 and are reluctant to upgrade to 17.10.
- You can still get protection from Meltdown security hole by manually installing Kernel version 14.14.13 today.
- You can get protection from Spectre security hole by manually installing Kernel version 14.14.14 in a day or two when Ubuntu Kernel Team releases it.
- Linux Kernel Team released 14.14.14 yesterday and Ubuntu Team is usually a day or two behind.
You can learn more from: How to update kernel to the latest mainline version without any Distro-upgrade?
WinEunuuchs2Unix
- 105,762
