The new 17.10 only has 64 bit ISOs. However 32 bit is still supported, there just are no live ISOs for it.
I have a 32 bit machine with WIFI, and I need to install from a USB disk. I tried the "mini.iso" but it doesn't have WIFI support.
What options do I have?
(PS I don't want another distro, and I can't use ethernet for installation, must be WIFI).
grokky
  • 143
Install Xubuntu 32-bit. After it's installed, install the Ubuntu desktop system package:
sudo apt install -y ubuntu-desktop ubuntu-wallpapers ubuntu-wallpapers-artful
sudo dpkg-reconfigure gdm3
sudo dpkg-reconfigure gdm3 will open up a new window allowing you to select gdm as the default login display manager. Select gdm3 and reboot.
sudo apt remove lightdm-gtk-greeter
sudo reboot
karel
  • 122,292
  • 133
  • 301
  • 332
