Tried using this: Installing Broadcom Wireless Drivers, but the [14e4:43a3] (rev 08) isn't listed.
Here's the pertinent output from: sudo lshw -C network
*-network UNCLAIMED
       description: Network controller
       product: BCM4350 802.11ac Wireless Network Adapter
       vendor: Broadcom Limited
       physical id: 0
       bus info: pci@0000:3a:00.0
       version: 08
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: memory:dc400000-dc407fff memory:dc000000-dc3fffff
I thought it was a kernel issue, but output from: uname -r
4.4.0-109-generic
The wireless was working recently, but between updates I think something happened.
Any thoughts? I tried running through https://help.ubuntu.com/lts/ubuntu-help/net-wireless-troubleshooting.html, but to no avail. Thanks for any help.
Edit 1: Per request, the output of: dmesg | grep brcm
[    9.299788] usbcore: registered new interface driver brcmfmac
[    9.299910] brcmfmac 0000:3a:00.0: enabling device (0000 -> 0002)
[    9.300085] brcmf_chip_recognition: chip backplane type 15 is not supported
[    9.300087] brcmf_pcie_probe: failed 14e4:43a3
[    9.355666] bluetooth hci0: Direct firmware load for brcm/BCM-0a5c-6412.hcd failed with error -2
[    9.355671] Bluetooth: hci0: BCM: Patch brcm/BCM-0a5c-6412.hcd not found
[ 3906.152283] bluetooth hci0: Direct firmware load for brcm/BCM-0a5c-6412.hcd failed with error -2
[ 3906.152285] Bluetooth: hci0: BCM: Patch brcm/BCM-0a5c-6412.hcd not found
Edit 2: Result of running:sudo updatedb && locate brcmfmac4350-pcie.bin
/lib/firmware/brcm/brcmfmac4350-pcie.bin
After running dmesg | grep brcm after following the steps:
[    9.733367] usbcore: registered new interface driver brcmfmac
[    9.733432] brcmfmac 0000:3a:00.0: enabling device (0000 -> 0002)
[    9.868201] brcmfmac 0000:3a:00.0: Direct firmware load for brcm/brcmfmac4350-pcie.txt failed with error -2
[   10.290149] brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 22 2015 06:16:26 version 7.35.180.119 (r594535) FWID 01-e791c176
[   10.307570] brcmf_cfg80211_reg_notifier: not a ISO3166 code
[   10.329437] brcmfmac 0000:3a:00.0 wlp58s0: renamed from wlan0
[   11.734155] brcmf_add_if: ERROR: netdev:wlp58s0 already exists
[   11.734155] brcmf_add_if: ignore IF event
[   11.905700] brcmf_add_if: ERROR: netdev:wlp58s0 already exists
[   11.905723] brcmf_add_if: ignore IF event
Ran sudo dpkg -s bcmwl-kernel-source and got:
dpkg-query: package 'bcmwl-kernel-source' is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
I Ran the purge anyways.
Really not sure what I did, but it's working now. Maybe I made a change before all of this, and it just needed the reboot?
Anyways, thank you for the help and I hopefully wrote up something in case someone else has the same issue.
J. Starnes
  • 1,979
Grant F
I'm not entirely sure what solved the issue, but purging bcwl-kernel-source and rebooting seemed to do the trick.
Grant F
