14
I recently upgraded to virtualbox 5.2.4 and vagrant 2.0.1 because of this issue. Since then, I haven't been able to run any of my vagrant boxes (some ubuntu, some centos). I get the following error when running vagrant up:
There was an error while executing VBoxManage, a CLI used by Vagrant for controlling VirtualBox. The command and stderr is shown below.
Command: ["startvm", "ef47d1fc-4ed1-42cb-b564-09bc2bb43296", "--type", "headless"]
Stderr: VBoxManage: error: The virtual machine 'ishbook-centos' has terminated unexpectedly during startup with exit code 1 (0x1) VBoxManage: error: Details: code NS_ERROR_FAILURE (0x80004005), component MachineWrap, interface IMachine
When I just run vboxmanage without --type headless, I get a popup saying to run /sbin/vboxconfig.
RTR3InitEx failed with rc=-1912 (rc=-1912)
The VirtualBox kernel modules do not match this version of VirtualBox. The installation of VirtualBox was apparently not successful. Executing
'/sbin/vboxconfig'
may correct this. Make sure that you do not mix the OSE version and the PUEL version of VirtualBox.
where: supR3HardenedMainInitRuntime what: 4 VERR_VM_DRIVER_VERSION_MISMATCH (-1912) - The installed support driver doesn't match the version of the user.
No luck even after running sudo /sbin/vboxconfig multiple times.
I've tried reinstalling virtualbox and the extension pack multiple times and reinstalling linux-headers and dkms as seen in answers to questions similar to this one, but nothing has worked. Any ideas?
Edit: Just tried it out on 5.1, but it's the same error, 5.0 just hangs my computer
7 Answers7
12
OK. Figured out the problem here. My kernel modules hadn't been deleted from the previous install of virtualbox when I uninstalled. So when I ran modinfo vboxdrv, it said I was using the kernel drivers for 5.0.4.
I deleted everything in the path to the filename given in the modinfo output and rebooted. Installing virtualbox and starting vms worked after that.
I found that a simple uninstall and reinstall of both VirtualBox and Vagrant solved this issue.
Each of the installers come with a uninstall script for convenience. Run this before installing. Ideally from a fresh boot of your system to ensure VirtualBox is not running.
I faced the same issue, I ran sudo /sbin/vboxconfig command in terminal and after its successful execution, I was able to start the vm.
Just had an issue where a system update clobbered my Virtual XP, giving the "rc=-1912" error, the suggestion of reinstalling, etc. What I found worked was sudo apt-get update sudo apt-get upgrade Seemingly overly simple but worked here!
BJM
  • 31
I had faced the same issue in macOS Mojave 10.14.6 and virtual box
Restart the Mac into Recovery Mode by rebooting and holding down COMMAND + R keys concurrently At the “Utilities” screen, pull down the ‘Utilities’ menu and choose “Terminal” to launch terminal from Recovery Mode Enter the following command:
spctl kext-consent add VB5E2TV963
Hit Return, then restart the Mac with a normal boot as usual
VB5E2TV963 this is the code for Oracle, found it raw but it worked for me...
Run:
VBoxManage startvm name --type=headless
Found it here: The virtual machine has terminated unexpectedly during startup because of signal 6.
Eliah Kagan
  • 119,640
bugz
Try running it with root permissions through sudo:
It worked on my case.
derHugo
  • 3,376
  • 34
  • 52
gerzenstl
  • 101
