I am trying to run Cuckoo sandbox in my Ubuntu 18.04 and got the sandbox VMs working in the headless mode. I want to see the STDOUT when the program is executing, for that I thought I will enable the GUI mode in virtualbox. I enabled the GUI mode by editing the mode parameter in virtualbox.conf.
Then I am getting the following error:
VBoxManage: error: The virtual machine '192.168.56.1011' has terminated unexpectedly during startup with exit code 1 (0x1)
VBoxManage: error: Details: code NS_ERROR_FAILURE (0x80004005), component MachineWrap, interface IMachine
I am getting the same error when I try to start the VM using the VBoxManage command standalone (without using Cuckoo). I saw that this error was posted by many people online, but the suggested solutions did not work (seems like there are many reasons that this error can come).
Standalone VBoxManage command I used:
VBoxManage startvm 192.168.56.1011 --type gui
System information: OS: Ubuntu 18.04
$ uname -a
Linux 4.15.0-210-generic #221-Ubuntu SMP Tue Apr 18 08:32:52 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
$ VBoxManage --version
5.2.44r139111
What I tried so far:
  1. Installing dkms and virtualbox-ext-pack packages and running sudo /sbin/vboxconfig
  2. Making sure I have the ~/.config/VirtualBox/VirtualBox.xml and it's not empty
  3. Suggestions given in VBoxManage is unable to start vm code NS_ERROR_FAILURE ubuntu 16.04
Please let me know if you have any suggestions to resolve this issue. Thank you in advance.
sammy17
  • 49
I've been struggling with this error in Ubuntu 22.04 until I found the error behind "NS_ERROR_FAILURE (0x80004005), component MachineWrap, interface IMachine". I tried to start my machine in console using vboxheadless:
$ vboxheadless -s "Your VM name"
VBoxHeadless: Error -610 in supR3HardenedMainInitRuntime! VBoxHeadless: dlopen("/usr/lib/virtualbox/VBoxRT.so",) failed: <NULL>
VBoxHeadless: Tip! It may help to reinstall VirtualBox.
Since the reinstall did not previously work I searched for new error and found this post https://forums.virtualbox.org/viewtopic.php?t=88900
Changing the owner of the folders bellow and fixed my issue. Don't know how but the folders were owned by my linux user instead of root.
sudo chown root:root /usr
sudo chown root:root /usr/lib
sudo chown root:root /usr/lib/virtualbox
VBoxManage modifyvm "vmname" --defaultfrontend headless
This solved the problem for me. My VM would fail to start with this error from the command line but worked from the gui or using vboxheadless.
D-bone
