My Optiplex 990 with ubuntu server 16.04.3 won't boot. I'm left with a flashing cursor in the top left. I have run into the spectre kernel issue with Kernel panic after update to 4.4.0-108-generic
I have tried following How to get to the GRUB menu at boot-time? to get into grub, but no amount of tapping / holding shift (or escape as listed elsewhere) has got me into grub.
I tried a live cd and ran boot-repair (https://help.ubuntu.com/community/Boot-Repair) and that succeeded in running but fixed nothing.
Any other ideas?
Zanna
  • 72,312
The top answer to the question you linked to explains how to get into the GRUB menu if pressing shift does not work. You just edit the file /etc/default/grub and comment out GRUB_HIDDEN_TIMEOUT=[some number]. Then you run sudo update-grub.
Since you can't boot at all, you can't do that so easily.
However, you can do it from a live system, so go ahead and boot from a live system as you did before.
Now you can set up a chroot. If you're not sure of the device label of your installation's root partition, try running sudo fdisk -l to identify it. You should see something in the output like
/dev/sda2 <numbers indicating size> Linux filesystem
Try mounting that partition:
sudo mount /dev/sdXY /mnt
where sdXY is the correct label. Then have a look to see if the mounted partition has the directories you expect to see in your root partition:
ls /mnt
If you see things like this (not necessarily exactly like this, but at least most of them)
bin    dev   mnt         root        sys   var
boot   etc   lost+found  opt         run   srv  tmp
home   lib   media       proc        sbin  usr
then you got the right partition.
If you have a separate boot partition, you will need to mount it. If you are not sure, check the file /mnt/etc/fstab to see if it has a partition mounted on /boot. Ignore any mention of a partition mounted on /boot/efi.
If you have a separate boot partition, mount it:
sudo mount /dev/sdXY /mnt/boot
where sdXY is the correct label of the boot partition.
We might need to bind some additional resources (I am not sure this is necessary in this case):
for d in dev sys run proc; do sudo mount --bind /$d /mnt/$d; done
OK, now enter the chroot
sudo chroot /mnt
Now we can act as if we are in our installed system. First let's edit the configuration file:
sudoedit /etc/default/grub
(or call your favourite text editor). Find the line
GRUB_HIDDEN_TIMEOUT=0
(it may have a different number, but that is not important). Comment out the line by placing # at the start of it, so it says
#GRUB_HIDDEN_TIMEOUT=0
If you do not have the above line, look for
GRUB_TIMEOUT_STYLE=hidden
and comment that out instead to
#GRUB_TIMEOUT_STYLE=hidden
check that the line
GRUB_TIMEOUT=[some number]
ends in a number greater than 0 (the default may be 10). Save the file and exit.
Run this command to write the configuration to /boot/grub/grub.cfg
sudo update-grub
Now you can reboot into your installation, and the GRUB menu will be forced to come up every time.
Zanna
  • 72,312
