I am an Ubuntu newbie and would like to install zlib1g-dev on Ubuntu 16.04.3 LTS.
The command:
sudo apt-get install zlib1g-dev
ressults in the following error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
zlib1g-dev : Depends: zlib1g (= 1:1.2.8.dfsg-2ubuntu4) but 1:1.2.8.dfsg-2ubuntu4.1 is to be installed
I've been searching around but I don't know how to fix this.
Some more info:
sudo apt-get -f install && sudo dpkg --configure -a
0 to upgrade, 0 to newly install, 0 to remove and 3 not to upgrade.
apt-cache policy build-essential libc6-dev libc-dev g++ libpcap-dev libpcap0.8-dev libpq-dev krb5-multidev comerr-dev libsqlite3-dev postgresql postgresql-9.3 zlib1g-dev
build-essential:
Installed: 12.1ubuntu2
Candidate: 12.1ubuntu2
Version table:
*** 12.1ubuntu2 500
500 http://gb.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
100 /var/lib/dpkg/status
libc6-dev:
Installed: 2.23-0ubuntu9
Candidate: 2.23-0ubuntu9
Version table:
*** 2.23-0ubuntu9 100
2.23-0ubuntu3 500
libc-dev:
Installed: (none)
Candidate: (none)
Version table:
g++:
Installed: 4:5.3.1-1ubuntu1
Candidate: 4:5.3.1-1ubuntu1
Version table:
*** 4:5.3.1-1ubuntu1 500
libpcap-dev:
Installed: (none)
Candidate: 1.7.4-2
Version table:
1.7.4-2 500
500 http://gb.archive.ubuntu.com/ubuntu xenial/main i386 Packages
libpcap0.8-dev:
Installed: (none)
Candidate: 1.7.4-2
Version table:
1.7.4-2 500
libpq-dev:
Installed: (none)
Candidate: 9.5.2-1
Version table:
9.5.2-1 500
krb5-multidev:
Installed: (none)
Candidate: 1.13.2+dfsg-5
Version table:
1.13.2+dfsg-5 500
comerr-dev:
Installed: (none)
Candidate: 2.1-1.42.13-1ubuntu1
Version table:
2.1-1.42.13-1ubuntu1 500
libsqlite3-dev:
Installed: (none)
Candidate: 3.11.0-1ubuntu1
Version table:
3.11.0-1ubuntu1 500
postgresql:
Installed: (none)
Candidate: 9.5+173
Version table:
9.5+173 500
postgresql-9.3:
Installed: (none)
Candidate: (none)
Version table:
zlib1g-dev:
Installed: (none)
Candidate: 1:1.2.8.dfsg-2ubuntu4
Version table:
1:1.2.8.dfsg-2ubuntu4 500
