I am trying to install ffmpeg in Ubuntu 16.04 and it has a dependency package zlib1g-dev. when running sudo apt-get install zlib1g-dev. I am getting the below error
 zlib1g-dev : Depends: zlib1g (= 1:1.2.8.dfsg-2ubuntu4) but 1:1.2.8.dfsg-2ubuntu4.1 is to be installed
I read somewhere it might be due to a issue in sources.list. I've checked sources.list file it seems to be fine and verified with this link ( https://gist.github.com/rohitrawat/60a04e6ebe4a9ec1203eac3a11d4afc1 ) and sudo apt-get update doesn't shows any error as well. Can you please suggest. Thanks!!!
EDIT 1: I've also followed solution on this link ( E: Unable to correct problems, you have held broken packages ) and executed sudo apt-mark showhold but it didn't print anything. So couldn't unmark anything also tried the solution with aptitude and the log by running sudo aptitude install zlib1g-dev was:
The following NEW packages will be installed: zlib1g-dev{b} 0 packages upgraded, 1 newly installed, 0 to remove and 17 not upgraded. Need to get 168 kB of archives. After unpacking 426 kB will be used. The following packages have unmet dependencies: zlib1g-dev : Depends: zlib1g (= 1:1.2.8.dfsg-2ubuntu4) but 1:1.2.8.dfsg-2ubuntu4.1 is installed. The following actions will resolve these dependencies:
 Keep the following packages at their current version:
1) zlib1g-dev [Not Installed]
Accept this solution? [Y/n/q/?] y No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 17 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used.
Answer for this is given by SeinopSys in Error installing zlib1g-dev you need to take note of the required package version (in your case = 1:1.2.8.dfsg-2ubuntu4), then run the command below to downgrade to that version:
$ sudo apt install zlib1g=1:1.2.8.dfsg-2ubuntu4
Then you can try re-installing.
