I previously asked a question on setting up a ipv4 to ipv6 tunnel.
I answered my own question and this is configuration output from my previous question here https://askubuntu.com/a/992872/13903
4: he-ipv6@lo: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 65516 qdisc noqueue state UNKNOWN group default qlen 1000
    link/sit 47.x.x.x peer 216.66.77.230
    inet6 2001:470:7b:616::2/64 scope global
       valid_lft forever preferred_lft forever
    inet6 fe80::2fbb:2226/64 scope link
However this has a @lo suffix next to he-ipv6. It looks right but it does not let me ping ipv6 address such as ipv6.google.com
I tried the same configuration with ip linux tools.
ip tunnel add he-ipv6 mode sit remote 216.66.77.230 local 47.x.x.x ttl 255
ip addr add 2001:470:7b:616::2/64 dev he-ipv6
ip route add ::/0 dev he-ipv6
Which got me the interface he-ipv6 with suffix @NONE. This configuration does work and this is the output I get:
5: he-ipv6@NONE: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1480 qdisc noqueue state UNKNOWN group default qlen 1000
    inet6 fe80::c0a8:1/64 scope link
What is the @ symbol mean next to the tunneling interface?
How can I change my configuration in my previous question to avoid getting the @lo suffix?
Tek
  • 348
Time to answer my own question again after some lenghty research! So according to this systemd.netdev manual I need the independent flag for my configuration to work.
Independent= A boolean. When true tunnel does not require .network file. Created as "tunnel@NONE". Defaults to "false".
However this isn't available until systemd announcement version 235.
Running command systemd --version it seems I'm running systemd version 234.
Systemd version 235 isn't available until Ubuntu Bionic Beaver
After switching all the strings in /etc/apt/sources.list from artful to bionic
Running apt-update and sudo apt install --only-upgrade systemd
I switched back again bionic to artful in /etc/apt/sources.list and doing an sudo apt update && sudo reboot.
Then I was finally able to get the Independent flag to work in my [Tunnel] systemd configuration which let me ping ipv6.google.com on every reboot! I'm a happy camper :)
Tek
  • 348
