I figured it out.
I created the following files:
/etc/systemd/network/he-ipv6.network
[Match]
[Network]
Tunnel=he-ipv6
/etc/systemd/network/he-ipv6-tunnel.netdev
[Match]
[NetDev]
Name=he-ipv6
Kind=sit
[Tunnel]
Independent=true
Local=192.168.0.x #Private IP if behind NAT or Public IP without NAT
Remote=184.105.250.46 #Tunnel broker's IPv4 address
TTL=255
/etc/netplan/01-netcfg.yaml
# This file describes the network interfaces available on your system
# For more information, see netplan(5).
network:
version: 2
renderer: networkd
ethernets:
he-ipv6:
dhcp4: no
dhcp6: no
addresses: ['2001:470:xxx:xxx::2/64']
gateway6: 2001:470:xxx:xxx::1
enp0s3:
Where 2001:470:xxx:xxx::2/64 is your Client IP address from tunnelbroker.net
Then reboot or restart your network with systemctl restart systemd-networkd && netplan apply
Update/Warning This won't work unless you're already using Ubuntu Bionic Beaver or specifically speaking Systemd Version 235. You need the Independent flag under [Tunnel] for this configuration to work on every reboot along with systemd version 235.
The Independent flag doesn't work in systemd version 234 and below. You can check your systemd version with systemd --version
