67
I am new to ubuntu, been using it for about a month now.
I created a desktop for MythTV, and so I use a dual monitor configuration (one monitor for watching shows, and one for everything else). But because i dont have the tuner(yet), I am just using Hulu desktop and some video files that i already have.
The problem is that when i open some applications, such as firefox, they open on the monitor that is playing the video. Sometimes they even open up behind the video application.
Is there a way to stick applications to a certain monitor, so that it will always open up on that application?
I was going to post an image of the display configure screen, but i am to new to post images. If you need to see an image of it let me know and i will email it to you. the image just showed my two screens, a 20" on the right, and one known as unknown on the left. The "Same image in all monitors" button is not checked.
The Samsung is the monitor i want it to open on, and the unknown is the tv that i watch the videos on. Firefox in particular always opens up on the tv whenever it was closed while maximized, and opens on the screen it was closed on when it was closed while not maximized. This is the biggest annoyance that i have with Ubuntu. I am coming to Ubuntu from mac, and have basic to mid-level terminal experience.
chazwh
  • 671
12 Answers12
40
If you do not have CompizConfig, install it (you need it anyway).
sudo apt install -y compizconfig-settings-manager
Go to CompizConfig Settings Manager > Window Management > Place Windows (make sure that this plugin is checked). Under the General tab you see the option Multi Output Mode. You have options like: Use Active Output Device, or Use Output Device with Pointer etc.
abc
  • 116
Vadim
  • 1,388
16
Something similar to this happened to me a while back. Try going to System > Preferences > Monitors. Make sure that the main monitor (your working monitor) is to the left and not the right. If the two monitors are different resoutions make sure that they both align at the top. I noticed this with my setup a couple months ago when I installed a monitor that was using a resolution way higher than my working monitor.
Another choice is to use devilspie. You can get Devilspie from the Universe repository.
Same behavior in Ubuntu 20.04: with the primary (built-in) display on the right, (sub-)windows open on the (wrong) left/dual monitor. Examples: Search messages window of Thunderbird being opened on primary display, System Settings window clicked on top bar of primary display.
A work-around solution was possible with Settings > Displays > Drag displays to match physical set-up: Shifting the left display down below approximately 50 % of the height extension of the primary monitor (i.e. compromising the physical set-up, but still keeping the secondary display to the left of the primary display) generated a behavior correctly opening windows on the primary display.
Zanna
  • 72,312
xyz
  • 71
I believe (if you have compiz enabled) that you can do this from the compiz settings manager using the place windows plugin. I've not done this myself, but if you play around a bit with the options you should be able to get the window to appear on the desired monitor.
RolandiXor
  • 51,797
I fixed it by using compiz-config-manager. install using
sudo apt-get install compizconfig-settings-manager
Go to General > General Options > Display Settings
Set Overlapping Output Handling to whatever display you'd prefer (the smaller or the bigger, not sure what to do when you have equally sized monitors?).
Also correctly setting the Outputs text field with your respective screen resolutions seemed to help in placing the windows better.
Mateo
  • 8,152
Gerard
  • 151
In System->Preferences select Monitors. Check "Show Monitors in Panel" then click on the monitor you want as default and hit the "Make Default" button. Log out and back in and there you go.
I've tried this a few times and it never took until I checked the "Show Monitors in Panel" box.
If the compizconfig method does not work on it's own (see Vadim's post), then you can try using the GNOME Tweaks manager, go to Workspaces > Display handling and select 'Workspaces span displays'
Drag a window to the desired monitor and then close it. Next time you reopen it should open on that same monitor. Seems that you have to do it for each application.
Tested with Ubuntu 18.04
kenshie
  • 101
Until you are able to repair, use Alt+Tab plus Alt+F7.
Greenonline
  • 2,182
Right Click on the window titlebar and select: More Actions -▸ Window Manager Settings. There choose Focus in the column to the left. Toggle option Active screen follows mouse.
If no other defaults are specified, windows appear on the currently active screen. With the procedure described above, mouse position defines this active screen.
BiberBb
In "Displays" using the "Launcher placement" drop-down, select the monitor you want apps to open on.
Aaron
Ubuntu 22.04, open the application, let's say TextEditor, move it to the second screen with the mouse and close it. We open it a second time and it opens on the second screen.
