After a fresh ubuntu install I had some problems with the mouse flickering and disappearing. I intalled the AMD drivers from AMD's website but after restart I got a graphics error so had to remove the installed drivers. After that I installed the radeon drivers so I was able to get my screen back up. The mouse is stopped flickering but my second monitor is not detected by ubuntu.
I tried to debug this but found no solution.
lshw -c video:
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc.
[AMD/ATI] Pitcairn PRO [Radeon HD 7850] [1002:6819]
sudo lshw -c video:
*-display
description: VGA compatible controller
product: Pitcairn PRO [Radeon HD 7850]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=fglrx_pci latency=0
resources: irq:48 memory:e0000000-efffffff memory:f7c00000-f7c3ffff ioport:e000(size=256) memory:f7c40000-f7c5ffff
*-display
description: Display controller
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
configuration: driver=i915 latency=0
resources: irq:47 memory:f7800000-f7bfffff memory:d0000000-dfffffff ioport:f000(size=64)
xrandr:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
DFP1 disconnected (normal left inverted right x axis y axis)
DFP2 disconnected (normal left inverted right x axis y axis)
DFP3 disconnected (normal left inverted right x axis y axis)
DFP4 disconnected (normal left inverted right x axis y axis)
DFP5 disconnected (normal left inverted right x axis y axis)
DFP6 disconnected (normal left inverted right x axis y axis)
DFP7 disconnected (normal left inverted right x axis y axis)
CRT1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.0*+
1680x1050 60.0
1400x1050 60.0
1600x900 60.0
1360x1024 60.0
1280x1024 75.0 60.0
1440x900 59.9
1280x960 75.0 60.0
1280x900 75.0 60.0
1360x768 59.9
1280x800 59.8
1152x864 60.0 75.0
1280x768 59.8
1280x720 60.0
1024x768 75.0 70.1 60.0
800x600 72.2 75.0 60.3 56.2
640x480 72.8 75.0 67.0 59.9
I'm a total beginner on desktop ubuntu, used linux only for hosting. I have a i7-3770 processor and Radeon HD 7850 VGA.
