I'm having a difficulty installing VLC 3.0 in Ubuntu Zesty. Using the official PPA. I added it using
sudo add-apt-repository ppa:videolan/master-daily
sudo apt-get update
And apt-cache show has it listed,
apt-cache show vlc | grep Version
Version: 3.0.0~~git20160813+r65787+62~ubuntu16.04.1
Version: 2.2.4-14ubuntu2
but when I try to install 3.0.0 with sudo apt-get install vlc=3.* I get,
Reading package lists... Done
Building dependency tree
Selected version '3.0.0~~git20160813+r65787+62~ubuntu16.04.1' ( [amd64]) for 'vlc'
vlc : Depends: vlc-nox (= 3.0.0~~git20160813+r65787+62~ubuntu16.04.1) but it is not going to be installed
Depends: libavcodec-ffmpeg56 (>= 7:2.6) but it is not installable or
libavcodec-ffmpeg-extra56 (>= 7:2.6) but it is not installable
Depends: libgles1-mesa (>= 7.8.1) or
libgles1
Recommends: vlc-plugin-notify (= 3.0.0~~git20160813+r65787+62~ubuntu16.04.1) but it is not going to be installed
Recommends: vlc-plugin-samba (= 3.0.0~~git20160813+r65787+62~ubuntu16.04.1) but it is not going to be installed
Is there another PPA that provides VLC 3.0 in Ubuntu Zesty? It seems that libavcodec-ffmpeg56 was renamed,
$ apt-cache search libavcodec ffmpeg
libavcodec-extra57 - FFmpeg library with additional de/encoders for audio/video codecs
And that now vlc-3.* needs to be built against the new library (libavcodec-extra57) and have its manifest updated from old name (libavcodec-ffmpeg-extra56)
I can't file a bug on this either because Launchpad doesn't support that. All I can do is write the maintainer using the Launchpad contact forum, which I did. No response back.
