Following the advice of @Takkat (Apply LADSPA plugin to input (microphone)), I tried to apply a plugin (SC4 Mono) to a newly created sink:
pacmd load-module module-ladspa-sink sink_name=ladspa-sink master=alsa_output.pci-0000_00_10.1.analog-stereo plugin=sc4m_1916 label=SC4mono control=0,100,400,0,0,3.25,0,0,0
The name of the sink was checked with the following command:
pacmd list-sinks
The name of the plugin was checked in the the folder:
/usr/lib/ladspa/
But running that command in the terminal returns:
Module load failed.
I use the default settings for the SC4 Mono plugin when loaded with Audacity for my command. In the end I would like to apply the plugin SC4 Mono to the Microphone Input of my soundcard, so that other programs receive the altered signal.
zelyev
There where two errors in my command:
Original command:
Module load failed.
Label changed to sc4m:
pacmd load-module module-ladspa-sink sink_name=ladspa-sink master=alsa_output.pci-0000_00_10.1.analog-stereo plugin=sc4m_1916 label=sc4m control=0,100,400,0,0,3.25,0,0,0
Module load failed.
Control values changed:
pacmd load-module module-ladspa-sink sink_name=ladspa-sink master=alsa_output.pci-0000_00_10.1.analog-stereo plugin=sc4m_1916 label=SC4mono control=1,1.5,401,-30,20,5,12
Module load failed.
Label and control values changed – success:
pacmd load-module module-ladspa-sink sink_name=ladspa-sink master=alsa_output.pci-0000_00_10.1.analog-stereo plugin=sc4m_1916 label=sc4m control=1,1.5,401,-30,20,5,12
Change summary:
label=sc4m
The correct labels for the steve harris plugins (http://plugin.org.uk/ladspa-swh/docs/ladspa-swh.html) seem to be the first part within the parenthesis next to the plugin name.
The control values must also be carefully chosen.
zelyev
